Solid Lifter Adjustment
Old Jun 29, 2007 | 08:54 AM
1970 Dave's Avatar
1970 Dave
Default Solid Lifter Adjustment
Those with solid lifters--how often do you adjust them?--the last few years I haven't put on more than a few hundred miles on the car. The motor starts, idles and runs fine.
SEMPER FI--1970 Dave
Old Jun 29, 2007 | 09:13 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
set the valve lash to the proscibed gap
place feeler guage between rocker and valve spring, tcghter till you feel a tug in the gauge when puliing it out
Old Jun 30, 2007 | 12:30 PM
no_rice_burners's Avatar
no_rice_burners
I check the lash once a year whether I need it or not. I only put a few hundred miles a summer on as well, but It doesn't take long to check it out so I do.
Old Jun 30, 2007 | 04:26 PM
stingr69's Avatar
stingr69
You should not need to adjust very often at all. The only reason to adjust is for valvetrain wear. You can go for a long time between adjustments after the initial break-in and recheck of a new valvetrain.
If you need a lot of adjusting, something is wrong.
-Mark.
Old Jun 30, 2007 | 07:51 PM
1BadRat's Avatar
1BadRat
You shouldn't need to adjust more than once a year if everything is good. I had one rocker that was always "backing off" but after replacing the rocker arm nut I never had any more problems. Once or twice a year, tops!
To Solid Lifter Adjustment
