I smell major :bs...
My block is a Dart Iron Eagle block but it's the STANDARD DECK height block..
I really don't understand enough about those details but I trust my builder...
Do you use less stroke or are you using 4.125 bore?
I'm using 4.155 bore and 4.0 inch stroke.. I could've gone with 4.185 bore but then I'd have to have the block sleeved if it would have to be bored again.. 4.185 is the maximum bore recommended by Dart
P.S. my machine shop (not the shop that built my engine but the shop that did the machine work on my 406 rebuild) told me that just by using a racing block (Iron Eagle or Little M) you will get 3 more HP due to added block stiffness... Never heared about that before..
Are you gonna have the 427 dynoed?
That 1.5:1 happens to be the same ratio I believe Olivier's new 434 has (6.0/4.0), as well as my 496 project (6.385/4.25).
If that "rated to 700+" engine does have 5.7 rods with a 4.125 stroke, it's only got a 1.38:1 ratio.
Now that you've said it, I remember what my builder said.. He was also talking about side load etc..
Why does engine building have to be that complicated
I'll keep my engine building skills to rebuilding and not building.. That stuff is way too complicated...
Yeah, I'll probably try to chassis dyno it eventually, that is really what counts anyway I suppose.
Yeah, I have only built 3-4 motors and of course didn't do the machine work on them anyway. I'm an expert in my own mind at least
By the same token an all aluminum block will "lose" up to some 40 HP, again, with all the same pieces. Some will argue it's due to block being
"rigid", we see it as "heat dissipation", or HP leaving through the material. The sleeves in an aluminum SB like Brodix are only about .075" thick per side and cannot "retain" enough heat from the charge.
We've been testing this for some years now with aluminum vs. iron blocks/heads.
Most recently tested a 434" (all aluminum) SB, 11* splayed (Jenkin's) heads, made 950 HP initially, made 975 HP with a simple pushrod change, 3/8" to 7/16". With a substituted "iron" race block AND some 1/2" pushrods we would have seen between 1025 HP and 1040 HP. The 950 to 975 is fact! The 1025/1040 is "guestimated".
Thanks, Gary in N.Y.
P.S. Below here is an excerpt by one Darin Morgan from another forum explaining more about the "material's" used in choosing the platform. In his summation he's comparing "cast" aluminum blocks to "billet" ones, but the part about the cast iron with aluminum is appropriate!
(Quote)
On another note,
A cast iron block with cast iron heads will make more power than any other combination.
A cast iron block with aluminum heads will make less power.
An aluminum block with aluminum heads will make even less power.
There are ways to help out the situation in order to minimize the losses but you will always be down a little with an aluminum block. Billet blocks seem to minimize the losses more than anything else. Thick cylinder walls will help but that limits over all power by limiting valve size so your really screwed coming or going.
_________________
Darin Morgan
R&D-Cylinder Head Dept.
Reher-Morrison Racing Engines
1120 Enterprise Place
Arlington Texas 76001
(End quote)
