Steering rack/pump compatibility
Old Jul 1, 2007 | 06:44 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Default Steering rack/pump compatibility
Just curious what the Steeroids conversion crowd is using for a pump. I'm getting a custom width rack built for my C4 suspension conversion, and am curious about re-using the stock pump. It's my understanding, and please correct me if I'm wrong, that pumps that connect to power boxes are quite a bit higher pressure than pumps that connect to racks. Seeing that our stock power system is an assist cylinder, rather than a power box, is the pump pressure a lower level that is compatible with most racks?
Thanks for the input and advice.
Mike
Old Jul 1, 2007 | 06:54 PM
mrvette's Avatar
mrvette
Pay attention to Jim Shea, he designed many of these systems, or knows who did.....his information is gospel, and you need do a search here/wherever you can find it....
BUT, I ran my stock '72 p/s system with a serp drive '87 vette pump and someone said use the '72 valving....that large brass nut the line screws into....so I swapped it over, and it worked fine from about '95 through '01, then I swapped to a '92 Grand Am rack, and lost track of the C4 valving....oh well, works fine....last year I added a hydroboost, and its fine....
go figger...
Old Jul 1, 2007 | 10:31 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
I'm using a stock pump with a flow control valve shim kit. I am using all 5 shims. The kit shows a remote reservoir type pump but the kit is the same for early attached reservoir pumps.
File Type: pdf
Old Jul 2, 2007 | 06:50 AM
Binnie77's Avatar
Binnie77
I am using my stock 90K mile pump with my steroids rack and it works fine.
To Steering rack/pump compatibility
