Replace my yolks?
My questions:
Is this a needed replacement common for a car with 90K?
Should it cost ~$1,000 for parts and labor?
Is it worth doing sooner than later or can I put it off for a while - what's the risk?
I'm NOT a mechanic by any definition so any other advice or comments would be greatly appreciated! Thanks in advance!
-Kevin
When done...you will also need an alignment. Have you noticed the top of your rear wheels leaning inboard? That is another sign of worn yokes.
Oh.. your other question. Yes do it now. They will start eating into the diff case which means you will likely be looking for a complete new unit. I am sure there are safety issues here too.
When you tear down the rear end of your car (1963-1979), the first think you should look at is the rear end yokes. The driver side yoke is the least likely to wear out. Yes this is common for a yoke to be bad, but the passenger side (drive side) is more common!
To inspect the yokes, take off the snap ring and pull the yoke out of the side of the rear end. If no snap ring is present, then after you remove the yoke inspect it for the snap ring groove. If there is no groove present (seen picture with snap ring installed) then the yoke is for sure defective or bad!
The best way to tell if a yoke is bad is to look at the tip. On a new yoke, there is a fluted edge about 1/8". (See picture). If this is gone then yes the yoke needs to be replaced. Failure to replace a bad yoke will result in the yoke shield wearing on the part of the rear end housing that holds the side yoke seal.
It is not un-common for the passenger side yoke to be worn, but for the driver side to be worn out is un-common! (Usually driver side failure is a direct cause from not changing the fluid in your rear end).
Many cars have positive traction rear ends. Do not confuse "duck waddle" while going around a turn with a bad yoke! Noise (popping sounds) heard on slow turns may be the lube in the rear end and the posi clutches sticking. The positive traction rear end units require the lube to be changed about every thirty to forty thousand miles. To do this you need 2.5 quarts of lube and 1 can of positive traction additive.
When you feel what we call duck waddle when turning, this means the clutch's are sticking in the posi unit and the wheels are in direct drive of equal proportion. Something has to give and thus you create what we term duck waddle. If you are feeling duck waddle then an additive and lube change may solve (and will quite often) this problem. You might need two cans of additive and you might also need to change the fluid after a few hundred miles to free up the clutches in the rear end.
Van Steel is correct too! If the car is torn apart, and the yokes are bad then go with the harden tip rear yokes. If the yokes are bad you might want to consider doing the entire rear end too! The metal off the worn yoke had to go somewhere, and in most case's it will end up in the oil which will eat the bearings up! The carrier, side yoke, front pinion or rear pinion bearings may be shot from the metal in the lube.
Establish what the cause is before spending the money.
Willcox Inc.
See link for picture:
http://willcoxcorvette.com/product_i...ducts_id=24512
