Moving battery
Old Jul 3, 2007 | 10:00 PM
sjmaster's Avatar
sjmaster
Default Moving battery
I don't like the battery residing inside the cockpit. Has anyone tried moving it to the rear somewhere under or ahead of the gas tank? With the battery boxes available today, this seems like a easy task by bending and tiggin up a nice stainless bracket system to bolt the box to. I suppose it would help wieght distribution too.??
Thanks all! Happy Fourth !! Hats off to our Armed Forces!!
Old Jul 4, 2007 | 09:40 AM
Durango_Boy's Avatar
Durango_Boy
Keep it safe. If it's vulnerable in a rear end collision there could be a lot of hazards associated with moving the battery to the back.
Why don't you want in in the battery box?
Old Jul 4, 2007 | 12:58 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Have you actually looked under the car? there's zero room ahead of the gas tank, thats where the diff crossmember and axles are.
As fas as weight bias, the vette is nearly perfect 50/50 weight distribution, more/less gas matters more since it's behind the axle
Old Jul 4, 2007 | 02:23 PM
birdsmith's Avatar
birdsmith
One of the better design features of the C3 Corvette is that (some of)the major weight masses are contained BETWEEN the wheels,reducing polar moment of inertia (look that up in your Funk & Wagnall's) and thereby improving the car's handling. That includes the battery. There are probably ways that you could get the battery moved out of the passenger compartment but the work involved would be excessive to say the least. If you're interested in safety, it wouldn't be that difficult to reinforce or even replace the existing battery box with something that's stronger and sealed better. As a point of comparison, Nextel (Winston?) Cup cars have the battery placed directly in front of the left rear wheel.
Old Jul 4, 2007 | 04:07 PM
Jims79's Avatar
Jims79
I'm not crazy about a battery sitting behind me either. But instead of moving the battery I purchased a sealed battery. I think that's a better solution for you.
Old Jul 4, 2007 | 06:55 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If you're worried about venting, buy an Optima red-top and forget about it.
Old Jul 4, 2007 | 08:39 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
Go with a sealed battery like Optima. If you still arn't quite happy with it, build a better top to seperate it from the interior ... wouldn't be that difficult.
The only other places I think you could locate it is actually behind the front wheels, but your going to have to do some rearranging of other components such as the gas tank vapor canistor.
Old Jul 4, 2007 | 08:54 PM
LYLE's Avatar
LYLE
If one is worried about safety look at all the C-3's that have no spare tire. Gm called the tire part of the safety items needed in a rear end hit.
Old Jul 4, 2007 | 10:48 PM
454Can-Am's Avatar
454Can-Am
I can only agree about the location of the battery.................. as long as there are no problems, it's fine where it is. If you have to get a jump............... it's a PITA !
What I ended up doing is what macoshark told me he did on all his vettes. Install battery terminals above your rear license plate (Jegs sells them !) run a positive cable back from the battery and a negative to the frame................... problem solved ! Most batteries now have both side terminals and top terminals. You can jump the car from the outside or hook a battery charger up and never have to go inside the car ! Rick
Old Jul 5, 2007 | 03:04 AM
Disco_Mike's Avatar
Disco_Mike
my battery was draining, so I took it to autozone.
It was fun watching the guy to find the battery under the hood.
(I can be an azzhat like that sometimes)
I showed him the battery behind the seat.
he replied he now new why the tester cables were so long.
Old Jul 5, 2007 | 03:43 AM
kayosnes's Avatar
kayosnes
Dry cell batery.!!!!!
Old Jul 5, 2007 | 12:39 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
It's better than moving weight away from the car's CG, even if it "helps" weight distribution.
To Moving battery
