Lower V heat shields
Old Oct 30, 2001 | 04:21 PM
mulchie's Avatar
mulchie
Default Lower V heat shields
I need to install the lower V shields on a 71 small block. I can't figure out where the two mounting positions are. It looks like it has to mount on both the motor mount and the block. I see a threaded hole in the block. Any help please.
Old Oct 30, 2001 | 04:36 PM
GaryS's Avatar
GaryS
Default Re: Lower V heat shields (mulchie)
On my 72 small block, each of the V shields has one bolt that goes to the lower, rear engine mount. On the passenger side, the other bolt goes to a hole in the block just in front and slightly above the starter. It shares this bolt hole with the spark plug "J" shield. I can tell you from practical experience, you want to disconnect your battery. You are VERY close to the hot wires of the starter. On the driver's side the V shield the other bolt to a corresponding hole in the block.
Gary
Old Oct 30, 2001 | 07:49 PM
flynhi's Avatar
flynhi
What is a V shield? For heat or for static control?
To Lower V heat shields
