Mechanical Advance Question
Old Jul 13, 2007 | 08:38 AM
RekaRoyal's Avatar
RekaRoyal
Default Mechanical Advance Question
Thanks for all this forum does for the Corvette community. I have learned a great deal through your postings.
I've run into a strange problem (to me) with the original distributor on my 69 L-46 Corvette.
The mechanical advance seems to be limited to about 9 degrees, yielding 25 degrees with the vacuum advance disconnected at 2500 rpm. Beyond 2500 it doesn't advance any further.
To accomplsh this I installed two silver springs from a #928 Mr Gasket kit, and re-used the orignal weights (which were in good shape). The heavy original springs were on it and it was hardly advancing at 2500 rpm before the kit.
A rubber advance limit bushing was in place on the main shaft cam, but I replaced that with the brass metal bushing in the #928 kit. The two bushings were the same outer diameter, measured with a caliper.
I found that there is about 3/8 inch up/down play in the main shaft of the distributor with only a single thin shim. I intend to shim to the play out of the shaft, and am curious whether this would be causing my mechanical advance limit problem? Or, won't this have any effect on mechanical advance, and should I remove the limit bushing on this distributor?
Old Jul 13, 2007 | 08:42 AM
BillPk's Avatar
BillPk
3/8"? That sure does not sound right.
Old Jul 13, 2007 | 08:51 AM
RekaRoyal's Avatar
RekaRoyal
Shocked me too, to have that much movement there.
It clearly needs to be shimmed, but would this cause my mechanical advance throw to be too short?
Old Jul 13, 2007 | 08:57 AM
BillPk's Avatar
BillPk
I would say that's a good chance.
Old Jul 14, 2007 | 08:55 PM
RekaRoyal's Avatar
RekaRoyal
Shimmed the main shaft to .007". Still only getting 9 degrees mechanical advance from initial.
Going to remove the advance shim next. Hopefully that will get me to 36.
Thanks in advance for any pointers.
Old Jul 16, 2007 | 03:58 PM
mpett1's Avatar
mpett1
No to highjack your post but where can you buy a spring kit?
Old Jul 16, 2007 | 04:16 PM
lars's Avatar
lars
There are no Delco distributors that only produce 9 degrees centrifugal timing with the stock weights. Chances are that you're getting some of the initial advance in right at your idle speed, and this is giving you a false indication of a short curve. You might want to measure the length of you advance limit slot and see if it has been altered...
Also, if you had 3/8" up-and-down movement of the shaft, you might want to make sure the upper shaft bushing is installed correctly - I've never seen a shaft with that much play in it.
Old Jul 23, 2007 | 05:46 PM
RekaRoyal's Avatar
RekaRoyal
Thanks lars. I used rubber-bands to hold the weights closed while measuring initial advance, and took the rubber-bands off to measure mechanical advance.
The advance limit slot doesn't look modified, but it's possible it was was carefully closed a little to avoid pinging by a previous owner. It's an original 11:1 L-46, so pinging would likely be a problem on straight 93 octane premium.
I'm going to take the limit bushing off this week, to see whether it gets me up to 34-36 degrees. I've been doping the 93 octane with Max Lead 2000 for as long as I've owned the car (5 years), so hopefully I can avoid pinging when I get advance problems solved.
I found my #928 spring/bushing kit at a local hot rod shop. Coolest auto parts store I've ever been in. The guy behind the counter at Napa directed me there for parts.
Old Aug 1, 2007 | 06:18 PM
RekaRoyal's Avatar
RekaRoyal
Removing the advance limit bushing seems to have solved the problem. Without it, I'm set at 15 initial and 35 total w/o vacuum.
The car seems much more powerful than it did before I started. Thanks for all the help!
To Mechanical Advance Question
