Back firing problems?
Old Jul 28, 2007 | 04:49 PM
agent kronus's Avatar
agent kronus
Default Back firing problems?
my 78 vette,(L48) has started back firing into the air filter when i rev it and has bangs coming from zorst at idle every 10 secs or so, seems to idle at about 1000rpm?
any ideas on my problem??
cheers
dave
Old Jul 28, 2007 | 05:11 PM
Mikes*Corvettes's Avatar
Mikes*Corvettes
cheers
dave
Sounds like timing.
this should help
http://forums.corvetteforum.com/show....php?t=1430339
Old Jul 28, 2007 | 06:19 PM
neilo's Avatar
neilo
If you have changed your plug wires double check the firing order.
Old Jul 28, 2007 | 11:21 PM
BigBlockk's Avatar
BigBlockk
Backfiring is a lean condition. Check the idle mixture settings, fuel filter and accelerator pump. What kind of carburetor is this and what is the initial advance set at?
BigBlockk
Later.....
Old Jul 29, 2007 | 04:04 AM
agent kronus
BigBlockk
Later.....
its a Q - jet, dont know what the advance is(what should the initial advance be on a L48 engine with headers)?, where abouts is the fuel filter and is a clean out job, or new one?,
Old Jul 29, 2007 | 06:37 AM
jotto's Avatar
jotto
Dave the fuel filter is a small paper one that can easily be replaced. It is located in the fuel inlet on the carb.
Old Jul 29, 2007 | 07:39 AM
ddale1977's Avatar
ddale1977
Dave, you need to do some reading (that's how I learned it) and ask a ton of questions.
Here is a post that will help you understand timing. Print it and the other articles (links) in this post and keep reading them. Get out under the hood and take a look.
Also, if you have the service manuals for your car, it will help you with the location and changing of the fuel filter. You can get manuals on ebay.
Doug
To Back firing problems?
