Best non-adjustable shocks ??
Old Jul 30, 2007 | 03:30 PM
77TexVette's Avatar
77TexVette
Default Best non-adjustable shocks ??
Hi there,
can you tell I am in the buying phase of my project now? The TKO is on its way, the Steeroids are ordered...but I'm quickly running out of available cash
Anyway, I know that ultimately I want to install dual adjustable shocks, but in the meantime I want to get this car on the road and wonder if you have any feedback regarding non-adjustable shocks for a 77.
My default choice was 4 Bilsteins, which I can get for about $280 incl shipping. However, I wonder if you have any feedback for the other brands such as:
Koni
Edelbrock
KYB
Heck, I'd even install a set of Monroe's until I get serious enough where I spend some $$ on adjustable units.
Michael.
Old Jul 30, 2007 | 03:33 PM
SIXFOOTER's Avatar
SIXFOOTER
KYB is a good moderately priced shock, had them on my 77 and loved them, got the same on the 81 I am building now
Old Jul 30, 2007 | 03:55 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Depends on your spring and spring rate. If you have a steel spring, the KYB GR-2's would probably be your best bet as they are cheap shocks and are good enough to get you by until your ready for the adjustable. If you have a fiberglass spring and it's 330# rate or less than again the KYB GR-2's (but special valved shocks). If you have a 360# spring or higher, you gotta go with the Bilsteins.
Old Jul 30, 2007 | 06:03 PM
shoptek's Avatar
shoptek
I put them on my '71 and am VERY happy with them.
Old Jul 30, 2007 | 07:05 PM
77TexVette's Avatar
77TexVette
Thanks for the feedback so far. I have a 330lbs VBP rear composite spring and 460 lbs front VBP GT springs. I don't think I'll change either of them for some time...
M.
Old Jul 30, 2007 | 09:18 PM
Vettkeeper's Avatar
Vettkeeper
With a fiberglass rear spring a shock with more damper is needed.
Old Jul 30, 2007 | 09:27 PM
77TexVette's Avatar
77TexVette
Greg, more damper than what, though?
It seems that for a 330lbs composite rear spring I could either go with KYB GR-2 (with special valving) or Bilstein? if it's a borderline call I'll go with Bilstein as the price delta isn't that great.
I wonder if anybody's using Koni or Eledbrock as shocks...haven't seen much of this and I don't know what their characteristics are compared to Bilstein or KYB.
M
Old Jul 30, 2007 | 09:38 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I'm running Edelbrock shocks with VBP fiberglass springs front and back set fairly soft. They ride slightly stiffer than the KB2's (special valving), but handle much better on a road course. The KYB2's were great for cruising, but I found them a bit soft when pushed hard. I've also tried the Bilstein sport shocks & KYB high pressure shocks and found both to be too stiff for Indiana roads. The Bilstein sports would probably be awesome on a road course, but it just wasn't worth the huge lose in ride quality.
Old Jul 30, 2007 | 09:49 PM
Retro78's Avatar
Retro78
Hey VBP... Why are Bilsteins required for a 360+ glass spring?
Old Jul 31, 2007 | 05:07 AM
stingr69's Avatar
stingr69
Originally Posted by carguy4sure
Hey Van Steel... Why are Bilsteins required for a 360+ glass spring?
Car Guy,
I fixed it for you.
-Mark.
Old Jul 31, 2007 | 08:45 AM
BB72's Avatar
BB72
I have a new 7 leaf in the back and I just picked up a pair of bilstein Xtremes. Does anybody know the spring rate of the 7 leafs and how that setup would work?
Old Jul 31, 2007 | 09:09 AM
Ganey's Avatar
Ganey
MA 603-083 should do it for you.
Old Jul 31, 2007 | 09:17 AM
Van Steel's Avatar
Van Steel
The bilsteins are valved for higher rate of rebound along with the compression and nose pressure. The KYB-GR-2 for the fiberglass spring has a lot less compression and nose pressure.
Old Jul 31, 2007 | 09:20 AM
Van Steel's Avatar
Van Steel
It's said that the 7 leaf is comparable to a 360# fiberglass spring. The extremes are what they are, extremely stiff. If you not autocrossing with them, make sure your teeth are in good order.
Old Jul 31, 2007 | 09:30 AM
Vettkeeper's Avatar
Vettkeeper
M
The reason I would sugguest a shock with more damper when using a fiberglass rear spring is with mine it rides much nicer then with the leaf spring, but when I go over a dip in the road I end up bumpin my head off the T-tops. JMO
Old Jul 31, 2007 | 09:44 AM
BB72's Avatar
BB72
My first vette had the gymkhana suspension with poly bushings...now thats stiff.
Old Jul 31, 2007 | 09:52 AM
mrvette's Avatar
mrvette
12 years ago when I got this '72 vert, I rebuilt the entire suspension, miss nothing, it moved, it was new...steering also, put on KYB with the VBP 460 fr/360 plastic rr springs....just last winter I changed over to the Bill Steins...and found it was a pleasant improvement, the roads around here are rough as a cob, and so it helped also with undulating bridges that tossing up and down gets old over 3.5 miles of bridge...gone with the Bsteins....
other changes over the years, but not with shocks...IMO...get the Bill Steins....right off, and don't look back....
oh, edit, I even tried going back to a steel rear spring....
forgetaboutit...junk.....
To Best non-adjustable shocks ??
Old Jul 31, 2007 | 05:22 PM
77TexVette's Avatar
77TexVette
Thanks for all of your feedback. 4 Bilstein Sport shocks are on their way. I think I'll be happy with them.
Some confusion I ran into are the different models of Bilstein you find for 63-82. Here's the rundown:
(a) Bilstein Sport, Bilstein part #F4-B36-0222-H0 and F4-B46-0232-H0.
(b) Bilstein Heavy Duty, Bilstein part #F4-B36-0946-H0 and F4-B46-0956-H0.
Bilstein's web site legend describes these as applicable for most "full size vehicles and SUVs" - doesn't make a lot of sense to me.
(c) VBP has this Bilstein Xtreme shock (VBP1010), which is not recommended for street according to their catalog.
I went with option (a) above, but don't know what the difference is compared to option (b). Vette catalogs (VBP, VanSteel) typically carry the Sports shocks, but I also see the HD shock being advertised on Ebay and general Automotive sites.
Old Jul 31, 2007 | 05:48 PM
Jims79's Avatar
Jims79
Best shock I used so far Bilstein, next would by KYB. You can't go wrong w/either.
Old Jul 31, 2007 | 06:06 PM
Kalway's Avatar
Kalway
For the price, KYBs are really good shocks. If you're sticking mostly stock, I wouldn't go with anything else.
If you wanna be competitive, gotta go bilstein.
