This is it, a 454 goin' inta an '80 L82.
All I can find are part numbers, but not any dimentions. Block hugger headers, for a C3 w/BB, and they hit on the pitman arm bracket where it ataches to the frame. Also hits on the steering box. Can anybody give me some measurements, or where I can get them. I have "heard", that a GM motormount is a GM motormount, but I ain't so sure 'bout that. First time loadin' a 454, done a few SBs.
From: Graceland in a Not Correctly Restored Stingray
I don't know if Moroso used the factory dimensions, but their solid mounts for C3's (same for SB and BB) #62530 is 1 3/4" from block surface to CL of the frame mount hole, and 2 5/8" between the frame mount flanges. When changing to them, I experienced no noticeable difference in position.
I've also converted form SB to BB, but used the Hookers instead.
Hope it helps.
If not, at least consider this as a TTT for your thread...
Ah,.....a number I don't have. 1 3/4". I'll check this with the mounts I have now. The headers are "supposed" to fit, but y'all know how that goes sometimes.
I switched from a SB to a BB in my '69. Two different part stores listed SB and BB mounts as being different, so I bought the BB mounts which were taller than the SB mounts, but they wouldn't fit my frame horns. I ended up using the SB mounts which fit prefectly.
some year(s) had shims (1/8") in the shape of a V that went between the block and mount, one or both side(?), for vettes with an A/C option i think. i looked into this when doing a swap, but could never figure out the reasoning. what i ended up with had the dimensions of the SB mount, 99% sure.
the frame horns were the same as far as i could find between the BB and SB on vettes. some chevelles and maybe other cars that had bolted frame horns were different btwn BB and SB i think . . .
All of your answers are pointin' at the headers, as bein' the prob.
I can mod them, but I'd rather have what is "right", than "Bubba-ize".
Many thanks to all, for the responces.
