Tuning a Demon 750...Grrrrr...
Old Aug 4, 2007 | 05:51 PM
69vettester's Avatar
69vettester
Default Tuning a Demon 750...Grrrrr...
The Engine is eccelerating fine it cruises pretty steady in any gear, its not rough at idle 700rpms. BUT it wont decelerate off Hi rpm without blam wham out both exhaust pipes!! I mean if I wind the motor up in any gear then let fully off the accelerator pedal..wham...wham..wham out both Pipes. I dont have any guages for testing vacuum. What needs a little turn or tweak, Anybody got any advice??. If I advance the dist a Little More could that end these explosions in the exhaust. Or maybe back the dist. off a hair..what would that do??
any feedback appreciated..Thanks in advance..
Old Aug 4, 2007 | 10:36 PM
Richard454's Avatar
Richard454
After-fire is the correct term. Basically an incomplete burn and it causes the fumes to explode in the exhaust system. Could be running rich- the Timing is not correct or you have an exhaust leak. You might want to do a search- I think a while back there was a thread on it.
BUT make sure you've got the timing dialed in BEFORE you mess w/ the carb or you'll never get it right. Barry K did a great How to on setting timing-
http://forums.corvetteforum.com/show....php?t=1430339
Richard
Old Aug 5, 2007 | 03:37 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Richard
Per Lars, most carb problems are ignition problems.
Old Aug 5, 2007 | 10:55 AM
69vettester
Thanks, Ill retime and see what happens.
Old Aug 6, 2007 | 09:05 AM
lars's Avatar
lars
Afterfire is usually a sign of a lean condition. What happens is that the engine goes sudden lean after you've slammed the throttle closed at high rpm. This causes lean misfire in some cylinders, and a near-perfect unburned fuel/air mixture goes right into the exhaust where it explodes. Richen it up. First, back your idle mixture screws out a tad to see if that fixes it. If not, bump the jetting up a couple sizes and try it again.
Old Aug 8, 2007 | 09:33 PM
Tonys96's Avatar
Tonys96
New headers ???
When my header gaskets leak it backfires on lifting from W.O.T.
Check the header bolts and see if they're loose.
Old Aug 8, 2007 | 09:40 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Lars is correct and you should try his advice first. Because the idle circuit influences part throttle and cruise. Turn your idle mixture screws out and see if the backfire goes away
Old Aug 8, 2007 | 09:50 PM
SILVERSIXX's Avatar
SILVERSIXX
and nice Vette....
Old Aug 11, 2007 | 08:01 AM
black83zee's Avatar
black83zee
3rd Gear
thanks, Lars.......i will try adjusting the idle screws! my car started backfiring after i connected an accel ignition box...i thought these boxes burned all the fuel with multiple sparks. car accelertes fine, but pops and bangs through the exhaust when i lift...especially after hard acceleration....i'm running a holley 3310 on a 355sbc and 5 speed...motor pulls 20" on idle...i have a small exhaust leak...i guess it could be any of these things...but you think it's 'cause of leaness?
Old Aug 11, 2007 | 05:06 PM
black83zee's Avatar
black83zee
3rd Gear
turns out to be an ignition timing issue! re-set the initial timing to 14* and she doesn't backfire anymore!....don't know how it happened, but the initial timing was set to 4*! i had taken the module out of the distributor and ran the magnetic trigger for my accel 300 box....perhaps the built-in timing and dwell of the box changed my original timing! anyway..it runs great now.....
To Tuning a Demon 750...Grrrrr...
