engine experts enter for a compression question
Old Aug 7, 2007 | 07:03 PM
1Z87L8's Avatar
1Z87L8
Default engine experts enter for a compression question
background
started smoking off idle out of left bank pretty bad last week
no noticable smoke at speed/higher rpm.
pulled the plugs on drivers side and found #5 oil fouled.
a little while ago i heated the car to operating temp,blocked
throttle wide open and ran a compression check.
the manual says crank over 4 times, says if first one is low
then a bad ring is the problem.
my problem is the book doesnt say what is considered low.
my results are 1st stroke 110psi
2nd 130psi
3rd 150psi
4th 170psi
and stayed at 170 for every crank there after
it looks as though the compression builds uniformly as there
was 20psi each stroke after the initial 110 to the peak of 170.
in case your wondering i have not tested the other cylinders yet.
any and all answers would be appreciated
Old Aug 7, 2007 | 07:08 PM
dannyman's Avatar
dannyman
Compression needs to be checked on all cylinders to compare to each other. May have just a bad valve stem seal!
Old Aug 7, 2007 | 07:11 PM
weimer20's Avatar
weimer20
Your compression check numbers are not looking bad really. The main thing is to compare readings between cylinders and to do a leakdown test. The symptom you are describing seems more like a leaking valve stem seal to me. Just my opinion but I'm sure others will chime in.
Old Aug 7, 2007 | 07:12 PM
weimer20's Avatar
weimer20
Great minds think alike.
Old Aug 7, 2007 | 11:22 PM
tigers123's Avatar
tigers123
Default alternative
A cylinder leak down test might help.
http://www.aa1car.com/library/leakdown.htm
Old Aug 8, 2007 | 08:27 AM
1Z87L8's Avatar
1Z87L8
i probably should have checked the rest on the drivers side yesterday but i wanted to get to a cruise night that is only held once a month and man are those exhaust manifolds HOT.
i will probably wait until this weekend to test the other 7 cylinders and see what i have compression wise.
leak down test i wont be able to do at this time
because i dont own the tool for it unless auto zone rents one.
i will post the other readings once i have them
To engine experts enter for a compression question
