Do I need new headlamp actuators?
Old Aug 10, 2007 | 02:32 PM
ericd's Avatar
ericd
2nd Gear
Default Do I need new headlamp actuators?
I just bought an 81 wednesday, and today while I was driving (headlamps were down) the lamps popped up (switch was in off position), and now they won't turn off. The switch still turns the headlamps on fine, and still does the interior lighting, but I can't get the headlamps to go down. I tried the vacuum switch too. I am a newbie, so any help would be appreciated.
Old Aug 10, 2007 | 04:06 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You probably do not need actuators. Sounds like you need a check valve.
Old Aug 10, 2007 | 06:15 PM
69vettester's Avatar
69vettester
Mine did the same..it was the relay..you need to check all the stuff in the diagram until you find the leak..
Old Aug 10, 2007 | 06:34 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
www.corvette-101.com
Check the link and at the upper right there are some troubleshooting steps to take and you should find the problem. Try checking the check valve first like suggested. Its easy to get to and easy to check. Just mark the lines and be sure to put them back on the same ports.
Old Aug 10, 2007 | 10:17 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Could be a simple vac loss or loose hose. The headlights system is designed to fail in the up position when there is a vacuum loss.
Old Aug 10, 2007 | 10:49 PM
...Roger...'s Avatar
...Roger...
The above diagram from Corvette 101 is wrong at the headlight switch.If hooked up by this diagram the lights will go down but not up(unless there is a leak in the small hose going to the relay or the relay itself leaks)and will create a vacuum leak in the on position.
Here is a corrected diagram.
On your problem -check the small hose that goes to the T at the relays between the actuators.If you "have" vacuum at the small hose T then one of the relays probably failed.If you "dont have" vacuum at the T then find vacuum and apply it to the T and see if the lights go down.If they do go down then find out why you dont have vacuum on the small hose coming from the pulldown.
Old Aug 11, 2007 | 04:19 AM
7T1vette's Avatar
7T1vette
The above suggestions are correct, but each year C3 had some changes to the vacuum system design. You need to get a schematic for your year and the method to search out vacuum leaks. It's not difficult, but you have to follow procedure and buy a vacuum gage.
Old Aug 11, 2007 | 01:05 PM
ericd's Avatar
ericd
2nd Gear
I'm glad I asked. After I checked the check valve and replaced everything, the lamps starting working fine. I'm guessing that means one of the hoses was loose, but I didn't notice any peculiar. But like I said, I'm a total newbie. Thanks for the help guys.
To Do I need new headlamp actuators?
