Dumb question, but....
Old Nov 5, 2001 | 11:09 PM
82dukman's Avatar
82dukman
Default Dumb question, but....
My enigine leaks oil from the rear area onto the exhaust. Smokes like he11 when stopped at a light. Don't notice any oil loss on the dipstick, and haven't gotten under there yet. Would this be oil pan gasket or rear main seal, or what? I'm kinda lost here. Not sure what to check. Plan on checking it out in the winter.
Small block 350 motor. Thanks :seeya
Old Nov 5, 2001 | 11:15 PM
QuickVet's Avatar
QuickVet
Default Re: Dumb question, but.... (82dukman)
usually the rear main seal. just take a look under there and it wont be hard to tell where its coming from.
Old Nov 5, 2001 | 11:18 PM
82dukman's Avatar
82dukman
Default Re: Dumb question, but.... (Vetteboy)
Thanks. Might as well check out/change the oil pump whileI'min there, after taking the pan off.
If it a hard job to replace the seal? I have the dealer shop manual but didn't check it out yet.
Old Nov 5, 2001 | 11:26 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
not too hard. You just drop the rear main cap and change the 1/2 seal on that part.
There are two "sticks" that go into some slots, they are also seals. Hard to explain, you will see when you get down there.
The difficult part, besides dropping the pan, is the upper 1/2 of the seal.
You can use a small non-sharp tool to push one side of it in and the other side will come out. Grab ahold of it and pull the old one out. There are tools that are basically a wire you use to install the upper 1/2 of the seal. You thread it up around the crank journal and then use it to pull the seal into place.
I like to install the rear seal offset. That means the two halves of the seal don't line up with the two halves of the main cap. I have always thought if they line up, there is a better chance at a leak. Use a little black RTV to seal up the area and you are done.
I would make sure it is not the valve cover gaskets leaking down on the back of the motor, or the oil pressure sending unit first.
Clean the motor really good an look for new leaks.
Good luck.
Old Nov 5, 2001 | 11:33 PM
82dukman's Avatar
82dukman
Default Re: Dumb question, but.... (BSeery)
Thanks Bseery. I think I'll get some Gunk degreaser and spray it all over and power wash it off. I thought about the valve cover gaskets but I wasn't sure. I guess I can live with it for another couple of weeks. Never thought about the pressure sending unit though.
Old Nov 5, 2001 | 11:41 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
Sending unit leaks have probably cause more rear main seal changes than leaking seals themselves !!!
daily_driver's Avatar
daily_driver
could be the oil sensor tooo...
mine leaked like a siv until i replaced it....
when driving that could easily wind up on your exhuast
Old Nov 5, 2001 | 11:42 PM
daily_driver
Default Re: Dumb question, but.... (daily_driver)
doh!
he beat me to it by 1 second
Old Nov 5, 2001 | 11:43 PM
82dukman's Avatar
82dukman
This isn't gonna be easy..... I can feel it :crazy:
Old Nov 5, 2001 | 11:45 PM
daily_driver
oil sensor??
its so easy it aint funny...
just screw it off...
and screw new one on..
they sell em at napa auto parts for like ~10 bux or soo..
its a pretty common part.
Old Nov 5, 2001 | 11:49 PM
82dukman's Avatar
82dukman
oil sensor??
I meant checking everything in the meantime. I have to start somewhere I guess
Old Nov 5, 2001 | 11:54 PM
daily_driver
yah i hear that....
but other more common oil leaks than a rear main seal are prolly tranny line..(did u check that oil level??)
and also power stearing.....
when driving the wind carries it onto the exhaust....
even a leaking fuel line by the fuel pump can do it (been there ...done that..)
so id say 1st to monitor the fluids and find out exactly what is leaking....
then check what side... then youve got it...
youll probably find it to be a combination of things
:jester :jester
murphy's law!!!
Old Nov 6, 2001 | 01:07 AM
JB's Avatar
JB
St. Jude Contributor
There's some stuff called "Dye-lite" you can buy at most auto parts stores that makes finding the exact source of leaks really easy. You put it in the oil and/or tranny fluid (it's compatible with both), run the car a few minutes, then get under the car with a black light. The leaks show up as a green glow, like it's radioactive. Helluva lot easier than cleaning everything under there up. Their webpage is http://www.tracerline.com
JB
'78SA
[Modified by JB, 11:26 PM 11/5/2001]
Old Nov 6, 2001 | 03:03 PM
theandies's Avatar
theandies
Default Re: Dumb question, but.... (JB)
A friend of mine has a 75 and he thought his rear main seal was leaking but when we investigated it, it turned out to be the rear corner of the valve cover gasket (Bubba put it on and the corner of the gasket was completely "squished" out) The bottom of his car looked like the Exxon Valdez. I guess you have an automatic (don't know the specs of the early 80's Vettes too well and don't know if a 4 speed was even offered in 82) take the torque converter inspection pan off the bell housing and inspect the rear main really good before trying to changed out the seal. Good luck and hopefully its something simple.
John
Old Nov 6, 2001 | 05:16 PM
82dukman's Avatar
82dukman
Default Re: Dumb question, but.... (theandies)
Thanks John. The underside of mine also looks like an oil spill :lol:
I think it might be valve covers or the rear main. Mine is an auto so I guess I will have to look at the rear main.Still think I might Gunk it before I rip it apart so I don't slide out of the garage :lol:
Old Nov 6, 2001 | 10:15 PM
82dukman's Avatar
82dukman
ttt
Old Nov 6, 2001 | 10:22 PM
Shutdown1's Avatar
Shutdown1
........Whoooeeee theandies (John) - Nice car!
[Modified by Shutdown1, 2:23 AM 11/7/2001]
Old Nov 6, 2001 | 11:59 PM
1979toy's Avatar
1979toy
Just remember that oil doesn't run uphill. If you have oil at the head, the problem is above there. Most likely cause is the valve cover, in my experiance.
Old Nov 7, 2001 | 12:08 AM
82dukman's Avatar
82dukman
Default Re: Dumb question, but.... (1979toy)
I know that's why I have to get under there!
To Dumb question, but....
