Fuel dripping
1. Incorrect float level. If float level is too high, fuel will drip from the nozzles.
2. High fuel pressure. Excessive fuel pressure can cause #1.
3. Excessive throttle opening. If the idle speed screw is cranked in too far, the carb will idle on the main discharge circuit instead of on the idle circuit. This can be cause by the following:
a. Insufficient initial timing. Check timing, timing advance, and fuinction of the vacuum advance control unit.
b. Carb setup problem. If the carb is a commercially rebuilt carb (see my postin on this), there are several internal issues that will prevent the carb from idling on the idle circuit, including modified power piston (cut lower stop), plugged idle air bleed holes (intentially installed lead plugs), plugged idle fuel transfer tubes, low float level, lean setting of the APT, lean jetting, warped airhorn eliminating idle fuel transfer, and incorrectly set idle mixture screws.
Good luck with the tuning!
Carb # Application Jet Rod Spring
17058211 CHEV 78 FED VETTE H.P. 77 53 17052057
17059216 Chevy 79 305-350 Camaro 72 40 17036019
I had similar symptons. I finally noticed a crack vacuum cap (primary) that was playing havoc with my idle.
replace all caps and lines.....
no problem
Make sure they havent blocked your fuel return line.
. I Finally said the heck with it and opened the carb up to check it out. The float was a bit high. But I checked the air horn for warpage and this is what I found. http://picasaweb.google.com/Walllparty/Carb It looks like the edges are lower than the center. Am I hosed?
I took some pics> http://picasaweb.google.com/Walllparty/Carb_plug
I guess that why the rebuilder drilled holes in my primary throttle plate. Now that I have removed the plugs I need to replace the throttle plates correct? I also found the float to be a little high and the power piston needing some adjusting as described in Lars Qjet tuning doc. Buttoned everything back up and retested on the car. Bummer, still have fuel dripping out my primary discharge ports. Oh, one other thing to mention. If I look down into the area around the secondary rods when the car is running, I can see fuel. Is that normal? The battle continues......
Send me the carb and let me test it.
