'78 acting strange
Old Aug 19, 2007 | 10:42 PM
sstan03's Avatar
sstan03
Cruising
Default '78 acting strange
I went out this weekend and as I was cruising down the highway, the RPM's jumped up for a fraction of a second then dropped from 3000 down to about 500. I briefly lost power (no acceleration, engine was still running). This happened again but this time, it had a major backfire through the carborator. Needless to say, it scared the poop out of me. More recently, I have noticed that when I start it up, it will run fine but about 5 minutes later (still idling), it will just die. I have not updated or changed anything. I have checked the vacuum lines and they appear fine. I have the L82 engine. Any help would be appreciated.
Thanks.
Old Aug 19, 2007 | 11:23 PM
Durango_Boy's Avatar
Durango_Boy
I would check the fuel system and ignition system.
You may have a clogged fuel filter or a pump that's going out.
The backfire could maybe indicate a timing problem or an ignition problem so I would also look into some preventative maintenance by replacing the plugs, wires, and coil under the distributor cap.
Old Aug 20, 2007 | 01:21 PM
Paul L's Avatar
Paul L
Have your local auto parts store check the ignition module in the distributor. Bring a hair dryer and make sure the module is hot at time of test. Sometimes they fail slowly and sometimes they just quit.
Old Aug 20, 2007 | 01:58 PM
rexx78's Avatar
rexx78
They are cheap but can leave you stranded with no spark. Don't forget the heat sink paste.
Old Aug 20, 2007 | 07:17 PM
sstan03's Avatar
sstan03
Cruising
Thank you all for your helpful suggestions. I will definately check it out and probably replace it and do a tuneup, you know wires and plug wires, cap and rotor.
Again Thank you for your suggestions.
To '78 acting strange
