Calling all ZZ4 Converts! Advice needed.
Old Aug 24, 2007 | 06:04 PM
toddalin's Avatar
toddalin
Originally Posted by theandies
Here' my tech tip I wrote a few years ago.
https://www.corvetteforum.com/techti...=167&TopicID=3
I pull my engine and transmission as one. I recommend an engine leveler and remove your hood. As added insurance I put a piece of plywood on my radiator "just in case". I can tell you that my ZZ4 is not a DOG and I know that it is not losing approximately 30% of it's power as suggested above. It is probably putting down around 290 to 300 to the road.
Show me the chassis dyno slips.
Old Aug 24, 2007 | 06:57 PM
69vettester's Avatar
69vettester
Originally Posted by PeteZO6
When I swapped out the engine in my '69 convert., I left the 4-speed Muncie in the car, and supported it with a floor jack. I did the entire job by myself in my home garage with a rented cherry picker. With just the engine to be concerned about, it was easy as it came straight up and out. I was somewhat concerned about lining up the trans input shaft to the clutch, but when I got to that part, it went smoothly. I made sure the engine and the trans were level and aligned. After jiggling the engine and rocking the car back and forth a bit with the trans in 4th gear, it went right home. Here's a photo of it coming out. http://www.myruffhouse.com/Out%20with%20the%20old.JPG
This is how it goes best for me too..especially with a Muncie..its light and 1 guy can muscle the trans snout right into the Pilot bushing ..usually without much problem.
Heres a Pic..
Old Aug 24, 2007 | 07:42 PM
jcswm's Avatar
jcswm
Originally Posted by Bob Onit
Thanks Tom
I think ill remove the hood
I'm starting to get things sorted somewhat.
I believe finding the correct flywheel will be a drag
Many variables... Bell housing style, starter nose cone, flywheel diameter, ring teeth, starter mounting holes on new block.....
The Transmission will bolt right up, the ZZ4 comes with a flywheel, get a starter, dipstick and tube for a '99 suburban
It's an easy swap ...... your making it sound A LOT harder than it is
You don't even have to worry about hood alignment when your done
I've lost a few lbs since then..... I did my motor swap not long after breaking BOTH arms!!!
Old Aug 24, 2007 | 08:05 PM
Bob Onit's Avatar
Bob Onit
I wish the ZZ4 came with a flywheel...... unfortunately, they don't.
Old Aug 24, 2007 | 08:13 PM
jcswm's Avatar
jcswm
From GM
Also included with the ZZ4 is an HEI distributor with an ignition timing advance curve developed for performance, a dual plane aluminum intake manifold that accepts your spread bore or square bore carburetor, an 8" high-RPM torsional damper, 12.75" auto trans flex plate and cast iron water pump.
Old Aug 24, 2007 | 08:22 PM
69vettester
I already had a Centerforce 2 pressure plate, disk , and Flywheel(for early 2 piece seal engine) on my old engine..the only thing I couldnt use with the new engine was the Flywheel I switched to Centerforce external balanced steel Flywheel for GMPP late zz engines. Got it at summit..it was expensive. Search summit for Late bolt pattern(1piece seal) Flywheels . But I can tell you not all Fit, Like the Hays..doesnt fit..its not for ZZ engines. The Centerforce advertises as "for ZZ engines". Got to be careful , I had to send the Hays Back.
Old Aug 24, 2007 | 08:27 PM
Bob Onit's Avatar
Bob Onit
Thanks Tom, thats good to know
I didn't want to spend big dollars on a brand new flywheel when theres thousands of used ones out there that only need to be machined
Old Aug 24, 2007 | 08:57 PM
jcswm's Avatar
jcswm
I missed that..... I thought you hd an automatic
i bought a lightweight flyweel for a 99 silverado for under $100.00
You will need to drill a hole & tap it for the "Z" bar ball ..... it took me less than 1/2 hour to complete with the right drill bits & tap
Old Aug 24, 2007 | 10:23 PM
billla's Avatar
billla
St. Jude Donor '14
I've installed a couple of ZZ4s, not in Corvettes. It's a good engine, and a solid performer for a reasonable price. It's not a screamer; the heads aren't all that great - they run out of flow about .450 in stock form and the cam...although the specs seem crazy for those of used to hydraulic flat lifters...is pretty mild. Using the published specs, you should expect about 280HP or so (if you have headers) at the road and a really nice, flat torque curve.
Another option to consider if you don't mind doing some assembly work is to buy the shortblock and put on some better heads (read: AFR ) and a bigger cam. I expect you'd come in around $5,500 or so.
If you're going crate shopping, I just suggest that you shop around a bit.
Old Aug 25, 2007 | 12:12 AM
Little Mouse's Avatar
Little Mouse
Thanks Tom
What is the the 6a - 6al Ignition and why do I need one?
I really didnt want to blow $350 on a dist.
I already have 2 tach drive units and a few HEI units but not for a manual tach.
Also, are you saying if the transmission is left in the car its easiest to leave the bell housing with the trans?
-EDIT- Ok, I see, the 6a goes with the MSD (more money)What I really need to know is if I can use my original dist and simply replace the gear.
Thanks again
If your buying the long block,
a new dist gear on your current dist. is all you will need at the most.
no reason to buy another Dist, unless yours is in bad shape.
new dist. gear is cheap. You can run a CDI box (6AL) on a
points distributor. 6A is the cheaper CDI, 6AL is the same thing
but with a rev limiter.
Old Aug 25, 2007 | 05:44 AM
Bob Onit's Avatar
Bob Onit
Thanks Mouse
I did buy the long block
Just had Lars bring an old spare tach drive back from the dead for me last winter.
The ZZ takes a melonized distributor gear and I ordered one yesterday
Old Aug 25, 2007 | 11:39 AM
theandies's Avatar
theandies
You’re telling me that my engine is loosing 125+ hp driving a water pump, alternator, 4-speed and a rear end. You've got to be kidding me. I don't need a chassis dyno to know that that is totally ridiculous. By your statement you’re saying that I am loosing almost 40% of my power running just what I listed above. I don't think so.
Normal parasitic power loss is between 15 and 20%. Let’s do some math so pay attention:
ZZ4 is rated at 355hp at the crank
355 x.20 = 284hp at the wheels
now what you're saying
355 x .35 = 230hp at the wheels
I put my loss at 15% since I am not running PB, PS, A/C, smog pump. I have headers + 2 1/2 inch exhaust.
Think what you want and I'll do the same.......I'm out
Old Aug 25, 2007 | 01:07 PM
  #33
billla's Avatar
billla
St. Jude Donor '14
Can't we all just get along?
Consider is that the 355 flywheel HP is on the engine dyno with dyno headers and typically open exhaust...or at least, no tailpipes. It's also an optimal dyno tune. If you're using stock manifolds, a full exahust and haven't had a dyno tune then I'd agree with around 240HP at the wheels max.
The easy solution is to drop $250 on a dyno tune - you'll get a better performing engine and a slip to show what you've got.
Old Aug 25, 2007 | 02:00 PM
  #34
toddalin's Avatar
toddalin
And therein lies the fallacy.
It's a simple matter to do a search of this forum and if you are thourough, and people haven't pulled them, you will find a wealth of dyno slips for ZZ3s and ZZ4s on this and the C1-2 forum. Just try to find one that shows more than 250 hp. Most show between about 225-240. Many ZZ3s are down around 205-225.
Old Aug 25, 2007 | 02:07 PM
  #35
billla's Avatar
billla
St. Jude Donor '14
I'll respectfully disagree; I've seen a number of engine dyno results on the ZZ4 putting it pretty close to claimed numbers. Common sense based on experience tells us that a 10:1 350 with decent heads and cam is going to make right around 1 HP/CID.
I wonder if you're confusing engine dyno and chassis dyno results. Here's one engine dyno example:
http://www.chevyhiperformance.com/te...ild/index.html
Old Aug 26, 2007 | 12:13 AM
  #36
toddalin's Avatar
toddalin
RWHP.
Old Aug 26, 2007 | 10:06 AM
  #37
billla's Avatar
billla
St. Jude Donor '14
RWHP.
Then I don't understand your comment that ZZ4's putting out 350 HP or so at the crank is a "fallacy". It is a dyno rating - as with most crate engines. No crate will make full rated HP in the chassis with a streetable exhaust, and you're not going to get close unless you invest (as previously noted) in a free-flow exhaust and it's properly tuned. ZZ4's aren't any worse in this regard than any other crate engine
If someone's making only 205HP from a ZZ3 then they've made some choices that have limited the ability to make power...and that has nothing to do with the engine itself.
And you've weighed in on this before - do you think your engine would dyno to "only" 365HP?
http://forums.corvetteforum.com/show...ht=ZZ4%2C+dyno
To Calling all ZZ4 Converts! Advice needed.
Old Aug 26, 2007 | 11:49 AM
  #38
billla's Avatar
billla
St. Jude Donor '14
Originally Posted by 69vettester
Start your own topics about your C3 engines..if you even Have one..which I doubt.
I have no idea what this is regarding. This is a ZZ4 thread started by Bob - if we're off-topic, his comment is welcome.
FWIW, I've built over 150 engines...
Old Aug 26, 2007 | 11:54 AM
  #39
Bob Onit's Avatar
Bob Onit
Doesn't bother me... I'm always interested in everybody's opinion concerning anything about the general topic.
Old Aug 26, 2007 | 03:35 PM
  #40
72 LT1's Avatar
72 LT1
I wish I had a scanner, so I could post dyno sheet, but I do not. I had my '72 vette on a Mustang chassis dyno on August 2nd . I run a ZZ4 w/ BG 650 mech.sec. carb, full length Flow- Tech ceramic coated headers and 2 1/2 inch Alens chambered 2 exhaust. I run a HEI tach drive dist. and have a M20 Muncie 4spd. PEAK HP is 258.7 at 5125 rpm and PEAK TORQUE is 301.2 at 3810 rpm. BOTH measured at the rear wheels. As you can see, this engine runs out of steam pretty early. Its not a HIGH rpm engine. What you cant see, is the nice flat torque curve from about 1800 rpm all the way to 4750 rpm. Always close to 300 ftlbs of torque to the GROUND. Not a super hi-po engine, but NOT a dog either. Hope this helps clear things up.
