Glad to see you're back Billa. It's fun watching this thread and scoping out all the different engines and cams. My engine builder is suggesting the Comp Cam XR264HR: This is VERY likely what we will go with.
HYDRAULIC ROLLER-
264 270 Adv. Dur.
212 218 Dur. @ .050
.510 .510 lift
110° lobe seperation
Great information - THANK YOU; this really makes the process quick and painless
Nice engine - very sweet torque and HP curve. That "doink" in the torque curve is giving me fits and I'm working with the DD folks.
The carb seems kinda big unless you'll be turning it high; the formula I use is CFM = ((CI x RPM)/3456) x VE...given that you won't need that carb until 7500 RPM or so.
Awesome. Thanks a ton for running the sim for me
I was hoping for better HP numbers, around the 460 range, but I guess we'll see if I ever get it on a dyno. As far as the carb, what size would you recommend, and are there any advantages to going smaller? And if so, which brand / setup do you recommend? I'm still a newb to carb cars so I'll take any advice I can get to increase performance and/or gas mileage
Thanks again!
thanks billa for your time. this will influence my cam choice. that cam seemed to be the best suitable for my a/t and 308 rears for now. if you have a better cam in mind im willing to try it out. thanks again colin75
Schmoky, REALLY sorry for missing you in the shuffle - thanks for the PM! I definitely wasn't ignoring you, occasionally I just get lost in the threads
Only comment is that the cam seems pretty mild given what I'd expect for flow numbers from those heads. I'm definitely not BBC guy - I've only built 5 or so and most of those have been pretty mild - but it seems like there's a LOT of flow beyond .500 lift, especially for a hydraulic roller. Going with an XR294HR tickled 500HP - probably TOO much for nice street manners. DEFINITELY not questioning your builder at all - they have the numbers to pick the right cam...only a comment from my limited view.
From: Las Vegas - Just stop perpetuating myths please.
How 'bout the Isky cams with Awilsons combo?
So how 'bout my request for the DD on the Isky cams with Awilson's 383" combo using stock heads?
"I would like to see how an Isky 270-Mega-cam would look on a DD - 270*/221*@.050"/108*LSA/.465"lift single pattern and maybe the 264 Mega - 264*/214*@0.05"/108*LSA/.045"lift. Then the same cams again but with 106* LSA. "
Very curious to see how they compare to the CC XE262/268 or the Crane cams (114142 Powermax, 2050 grind 216/228 454/480 112 LSA) he listed?
He may have stopped posting on that thead but it would make a usefull comparsion for the rest of us.
The recomended XR 264 HR cam seems a lot too small for a 10.3 to 1 big block.XR274HR Better.
Generally, the smallest carb consistent with the needs of the engine will give the best driveability and performance - with the major exception being racing where the throttles are slammed 100% open. The benefit to a smaller carb is better intake velocity which generally gives better throttle response.
IMHO a 650 or 700 is fine, but you can stick with what you have. I don't have a strong preference for brands - any carb works if it's working properly and tuned. Either way, invest in a good dyno tune and you'll be happy.
Thanx a bunch Billa. Your numbers are pretty close to what my builder said they would be. I asked him if he could run the flow numbers but they don't have a machine for that. I think the XR294HR would lose some on the bottom end torque wouldn't it? The numbers say the operating range is 1800 to 5800 VS 1200-5200 on the XR264HR. BUT maybe that wouldn't be too bad. If you have a file with the XR294HR dyno run on it could you please either post it or email it to me? I would love to have a look at it. ( cschmok@yahoo.com ) Now you have me thinking again. (damn look at all the choices )What about the XR274HR or any of the above and playing around with the lobe seperation a little.
I'm looking at getting 500HP or real close to it. With a fairly flat torque curve from 1500 - 5000 rpm. Is this even possible? Or am I dreaming? I also don't want to run the motor higher than 5500 rmp. (eek: the closer I look at this the more I think I am dreamin') As mentioned before it will be a hi-way cruiser mostly but do want the low end torque so when I go to the track a couple of times a year I won't be too embarassed.
That cam seemed to be the best suitable for my a/t and 308 rears for now. if you have a better cam in mind im willing to try it out.
IMHO it's not so much the cam choice as just the heads are pretty mondo for your overall combination. My concern with more cam is that you'd use more of the capability of the heads, but it'd be a dog off-idle to 2500 RPM or so...and with those gears and an AT it's definitely a concern. I'm happy to dig in a little deeper if you want me to really look at this.
Im In Process Of Piecing My Topend Back Together. Im Looking For Cam Recommendations That Will Still Run Vacume Acc. I Will Be Buying Roller Rockers And 2000 Stall. I Dont Think Ill Be Revving Past 5500 . Maybe After A Few Colorado Koolaids. Mainly Looking For Good Pull And Throttle Response. Thanks Colin75
I'm pretty much out of steam on that build - I ran over 20 DD's just to get the data we already had...and in the end as noted there was < 5% difference between them. It was a good thread...but exahusted from my perspective
Given the RPM, I'd stick with what you have for a cam. Again, the heads are the challenge - you may find that given the flow and size that you'll need more gear to be happy. Adding more cam is likely to just make the situation worse.
If you're not turning over 5500, you definitely don't need roller rockers - roller tip, maybe.
I think the XR294HR would lose some on the bottom end torque wouldn't it? If you have a file with the XR294HR dyno run on it could you please either post it or email it to me? What about the XR274HR or any of the above and playing around with the lobe seperation a little.
I'm looking at getting 500HP or real close to it. With a fairly flat torque curve from 1500 - 5000 rpm. I also don't want to run the motor higher than 5500 rmp. As mentioned before it will be a hi-way cruiser mostly but do want the low end torque so when I go to the track a couple of times a year I won't be too embarassed.
500HP is definitely within reach (only 1.1 HP/CID) although without flow numbers on the heads it's really hard to say with any certainty. Your builder is probably estimating flow based on his eyeball on the heads and experience - so the cam selection may be purposefully mild due to low flow heads. Given this, I'm really hinky about making any recommendations. LSA isn't really the question here IMHO - it's lift, and that's based on flow. IMHO this is a discussion to have with your builder.
As colin75 says you're a great man to have on this site. Your knowledge, experience and willing to help is a definet benefit for its members. You've given me some things to think about and WILL discuss them with my builder. Thanx for your help and input.
shmoky
PS I take it you didn't have the file of the DD run on the XR294HR. If by chance you do please post or email to me at cschmok@yahoo.com
thanx
