The stock cam in a 74 LS4 was about 440/440 with 210/210. Just wanted to see what the Comp HE 260 with 475/475 - 212/212 would do over the GM stock.
I do appreciate it and have a great Christmas!
If my references are right, the LS-4 produced 275HP/390TQ. You're picking up some good power - but IMHO it's far too mild of a cam given the heads. The stock manifolds are hurting as well - if you can't do headers from an originality perspective I would at least consider having the stock manifolds extrude-honed to pick up some power.
Folks, I think I'm caught up again. Please remember that I have a "day job", so I won't always get to these right away. If you have something really urgent (i.e.,you're doing an immediate build and trying to make some decisions) PM me...but otherwise I'll get to the requests as soon as I can.
No propblem Billa. Most of us have that "Nasty" day job anyway. Sure do appreciate your time and effort doing these dynos. I will get the cam card from the builder and then repost later.
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Thanks Billla... ... but it's "the wife's car".
We can't put the local HS art teacher in something too RAD !
Another failure for me..... Sorry I couldn't help with this one.....
No-problem at-all.....
I'm sure most everybody in this thread apprecaites the time you have spent on it:
most of this stuff is just 'guessing', but your work may help some of us make INTELLIGENT guesses.
Billa, maybe the problem is this is a custom grind. What specs do you need ?
That would be it Usually for a custom grind the vendor sends a complete cam card with the cam...but here's the information I need for a valid (within simulation limits) run. Ignore the Lifter acceleration rate as it's calculated from seat (.006) and .050 cam event timing.
Thanks for the run. I was wondering if I could ask for a second run using a some different tweaks. Would it be possible to tweak my model with the following changes:
1.52:1 roller tip rockers
.015 thickness steel shim head gasket
Installing the cam 4 degrees retarded (to keep DCR in the right range)
Motor is not built yet, so you are being very helpful.
Oh, and one question, did DD allow you to specify the rams horns with the bigger dumps, or did you have to use the standard ones?
Thanks again
-Fred
Billa,
I've revamped and would like to get an updated run if possible. I've changed a few things to get he compression ratio, quench and DCR more usable. Can you re-run my sim with the following changed parameters? Everything else is the same.
++++++++++Lower END++++++++++++++++
• 355 Cubic Inch sbc
• 4340 Forged Super Light Crank, 43 lbs
• Premium 6.000" I-Beam Rods
• 390 gram SRP Flyweight Pistons
• 7/16" ARP Cap Screw Bolts
• 1/16" x 1/16" x 3/16" Ring gaps
SRP Flat Top Pistons
• Piston #157064 • 3.500 Stroke • 4.030 Bore
Compression Ratio
•58cc •64cc •70cc
•11.2 •10.4 •9.7
Iron eagle heads
+++++++Heads++++++++
64
CNC Machined Combustion Chamber: No
Intake Runner Volume (cc): 215cc
Exhaust Runner Volume (cc): 75cc
CNC Machined Intake Runner: No
CNC Machined Exhaust Runner: No
Intake Port Location: Standard
Exhaust Port Shape: Square
Exhaust Port Location: Standard
Spark Plug Style: Angle
Intake Valves Included: Yes
Intake Valve Diameter (in): 2.050 in.
Exhaust Valves Included: Yes
Exhaust Valve Diameter (in): 1.600 in.
Valve Springs Included: Yes
Maximum Valve Lift (in): 0.620 in.
Outside Diameter of Outer Spring (in): 1.437 in.
++++++++++++++Intake / carb+++++++++++++++++++++
quadrajet tuned by a pro
edelbrock performer 2120 (or whatever one is stock replacement)
_++++++++++++++++cam+++++++++++++++++++
100 % stock cam for l82
(I don;t know if I'm cchangine that)
Guys, I've just been buried at work, school and real life. I'm working to get back in the saddle after the holidays, so just bear with me. I'll get to what I can get to when I can get to it.
