Desktop Dyno request thread
Old Aug 29, 2007 | 01:17 PM
  #41
SLVRSHRK's Avatar
SLVRSHRK
Originally Posted by billla
Fred, this was actually pretty easy - the only unknown here is the head flow numbers. I had a file for the '041s that were professionally ported and used that one...but there's clearly no way to tell exactly what yours are flowing without a bench report.
The only comment I had was regarding quench - .064 (if my math is right) is terrible If the block and heads are flat, I'd consider using a steel gasket to drop it to .042 - better. Not an immediate thing...but something to consider especially if you've had problems getting a full 36 degrees of total advance. Probably a nit, but it crossed my mind.
Thanks for the run. I was wondering if I could ask for a second run using a some different tweaks. Would it be possible to tweak my model with the following changes:
1.52:1 roller tip rockers
.015 thickness steel shim head gasket
Installing the cam 4 degrees retarded (to keep DCR in the right range)
Motor is not built yet, so you are being very helpful.
Oh, and one question, did DD allow you to specify the rams horns with the bigger dumps, or did you have to use the standard ones?
Thanks again
-Fred
Old Aug 29, 2007 | 01:28 PM
  #42
billla's Avatar
billla
St. Jude Donor '14
Fred, no change with the rockers; DD doesn't model to this level in terms of the benefits of rollers. Also no change with the gasket; I'd expect you'd see this more in the timing the engine can tolerate vs any significant power gain.
I think you mean advancing the cam - retarding the cam moves the power up in the RPM range and is generally not done. Advancing the cam 4 degrees moves the power peaks down about 500 RPM.
DD models "stock manifolds" and "stock HP manifolds". I use the latter. If the manifolds have really been heated up, then we'd expect to see about a 30 HP increase.
Old Aug 29, 2007 | 01:29 PM
  #43
big_G's Avatar
big_G
For forced induction, there's additional information required. I don't have a lot of experience with DD here - so we may get complete
DD wants either the specific blower model (Vortech, Paxton, etc.) or:
Island flow cfm
Impeller speed rpm
Peak efficiency %
Belt ratio
Boost limit psi
Pressure ratio
Internal ratio
Intercooler %
Here's a sample screen:
Pro-Charger D1-SC, Impeller speed 52,000 rpm, internal ratio 4.1:1, belt ratio 2.13:1. That is all the published info. form ProCharger. If it won't take...don't sweat it.
Old Aug 29, 2007 | 01:50 PM
  #44
Dr.G's Avatar
Dr.G
This is a great tool you have come up with. Here are my #'s. And thanks for the useful tool that you have given to us.
Dave
454 BBC
Comp. 8.75:1
Cam 24502611 Hyd. Roller
Lift .510 I .540E
Duration .050:211I 230E
Heads 118 com. chamb. Cast Iron
Intake 2.19
Exhaust 1.88
Rockers 1.7:1
Holly 770
Air Gap Int
Headman 2-1/2 in. headers
My goal is to squeeze another 100 HP or so out of this. What cam and Head combo would you recomend? If you have that info.
Thanks again, Dave
Old Aug 29, 2007 | 02:05 PM
  #45
Glensgages's Avatar
Glensgages
..... just for *****-and-grins.....
I plan-on using the as-OEM-built L-83 short-block from my 27,000 mile '82 Corvette for an upcoming bracket-race project:
don't know the exact particulars of the engine, other-than what is found on-line, and common-knowledge ~
4.000"-bore x 3.480"-stroke
9:1 compression with 76cc heads, unsure of valve-relief cc's
pistons 'typically' .025" down-the-hole
Since reliability/durability is imperative, the motor will-NOT be run as-hard-as it could, nor do we expect killer ET/MPH figures:
with 5600 RPM shift-points & trap-speeds, we are hoping for high-12s at 105 MPH.
To the stock bottom-end, we will add:
Edelbrock RPM-Performer heads, #60999
http://www.jegs.com/webapp/wcs/store...10002_69948_-1
Edelbrock Victor Jr intake, #2975
http://www.jegs.com/webapp/wcs/store...10002_27930_-1
Holley 750 cfm, double pump carb, #4779
http://www.jegs.com/webapp/wcs/store...10002_28022_-1
Comp Cams 292H Magnum cam
http://www.jegs.com/webapp/wcs/store...10002_29602_-1
Dynomax ceramic-coated headers (unknown diameter or length )
http://www.jegs.com/webapp/wcs/store...10002_16256_-1
Using the same carb/intake/cam on a 10.3:1 355" SBC with DART Iron Eagle heads, a 3700-pound '79 Z28 runs steady 12.80s @ 105 with 5800 RPM shift-point/trap-speeds (8" converter, 4.11-gears and 28" x 10" Goodyears on 8" wheels ):
I have felt the Z28 is making close-to 400 crank HP, but that might-be optimistic.
:bb
REGARDLESS of what HP/TQ levels we reach with the L-83 short-block, these are the parts we will use, as they are readily-available, and relatively-inexpensive:
we feel the above combination will make decent power, and if RPMs are kept-below 6000, it 'should ' last a few seasons, until I can buy a ZZ383 crate-motor.
Bracket-racers aren't paid-enough to 'go-fast', only to 'leave on-time', and run-the-number.
Thanks-in-advance!
Sincerely, Glen!
Old Aug 29, 2007 | 02:20 PM
  #46
billla's Avatar
billla
St. Jude Donor '14
Dave is that a factory P/N on the cam? I also need to the casting number from the heads.
Old Aug 29, 2007 | 03:19 PM
  #47
1fastC3's Avatar
1fastC3
All I can say is...whew Hope you've got some solid gears there
how much error +/- are in the dyno sim calculations? as for my gears, its a wide ratio BW T10 with factory 3.42 in the rear, I want to get a 4.11 gear set but would like to swap a whole unit so as to cut down on parked in the garage time.
-alex
Old Aug 29, 2007 | 03:48 PM
  #48
billla's Avatar
billla
St. Jude Donor '14
Error implies accuracy I wouldn't take anything to the bank here; it's just a sim. I've GENERALLY found that the HP numbers are in the ballpark to a bit conservative if the flow and cam numbers are right. Torque is generally optimistic to +10%
I want to be really, REALLY clear here - these are estimates that come from a computer program with a human bean making best guesses. I take no responsibility for the "accuracy" of the information.
Old Aug 29, 2007 | 03:51 PM
  #49
Dr.G's Avatar
Dr.G
this is a GM Crate 454 HO as far as I know they are GM #'s
The head #'s are 14096801.
Old Aug 29, 2007 | 04:15 PM
  #50
dgruenke's Avatar
dgruenke
Has anyone out there had their engine dynoed on an engine dyno yet? If so, let's try the combo and see how close DD is.
Old Aug 29, 2007 | 05:17 PM
  #51
Glensgages's Avatar
Glensgages
Couldn't you simply feed all pertinent datafrom a 'known' engine, like the ZZ383 or ZZ502 crate-motor, into the dyno-sim, and see if it's calculations match-up with what the GM dyno recorded?
ZZ383 (425HP/449TQ )
http://paceperformance.com/index.asp...D&ProdID=73193
ZZ502 (502 HP/567 TQ )
http://paceperformance.com/index.asp...D&ProdID=26942
Old Aug 29, 2007 | 05:39 PM
  #52
billla's Avatar
billla
St. Jude Donor '14
Originally Posted by Glensgages
[B][COLOR="DarkRed"]Couldn't you simply feed all pertinent datafrom a 'known' engine, like the ZZ383 or ZZ502 crate-motor, into the dyno-sim, and see if it's calculations match-up with what the GM dyno recorded?
As noted in my initial post, I've done this - I've "built" a significant (over 50) number of crate engines in DD and compared very closely. That's been my validation...plus a little common sense/experience.
dgruenke's right though - getting any results from the forum on the forum would be great!
Old Aug 29, 2007 | 07:27 PM
  #53
Glensgages's Avatar
Glensgages
My-mistake..... I forgot your original post.
Old Aug 29, 2007 | 07:44 PM
  #54
billla's Avatar
billla
St. Jude Donor '14
No worries at all - it's great thinking
Old Aug 29, 2007 | 08:10 PM
  #55
Gearhead74's Avatar
Gearhead74
Default Thank You
I really appreciate the work and time spent running this HP analysis on my engine. Thank you.
Bob
Old Aug 29, 2007 | 10:31 PM
  #56
billla's Avatar
billla
St. Jude Donor '14
Bob
Most welcome, Bob - I hope the information was useful!
Old Aug 30, 2007 | 08:17 AM
  #57
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
Thanks for the chart!! I know its only a sim but it gives an Idea. When I built the engine 3years ago, my goal was 300hp, I think its safe to asume I have reached it and maybe a little +. Its a wonderful little engine, very drivable.
Thanks again !!!
Michel
To Desktop Dyno request thread
Old Aug 30, 2007 | 06:25 PM
  #58
XLAR8R's Avatar
XLAR8R
Originally Posted by XLAR8R
Hey Billa, I been debating over actually getting it dynoed. Pretty mild setup and this one will be easy for ya. Thanks in advance.
350 .060 over stock bottom end with dish pistons.
stock vortec heads (excpet a little bigger springs to accept bigger then stock cam). the modified ones from SDPC.
Edelbrock Performer with 600 Holley.
1 5/8" ceramic Flowtech headers to sidepipes.
Comp XE262 cam http://store.summitracing.com/partde...2&autoview=sku
that work for ya ?
I'm guessing 9.5 on the compression tks a bunch.
Old Sep 3, 2007 | 02:32 PM
  #59
billla's Avatar
billla
St. Jude Donor '14
I'm going to bag on this one I just don't know enough about the forced induction on DD to know what I get when I don't have all the data and I don't want to post complete BS :/ Sorry, dude...
Old Sep 3, 2007 | 02:35 PM
  #60
billla's Avatar
billla
St. Jude Donor '14
Here's my shot :
