line adapter needed
Old Aug 24, 2007 | 09:22 PM
SIXFOOTER's Avatar
SIXFOOTER
Default line adapter needed
I need a 1/4" hard tube to 6an female adapter, any ideas where I can get one of those?
Summit, Nope
Jegs, Nope
same thing as Erls 165056ERL for earls, but for 1/4 instead of 5/16"
Old Aug 24, 2007 | 09:46 PM
Ironcross's Avatar
Ironcross
Aircraft! ...
Old Aug 24, 2007 | 10:02 PM
SIXFOOTER's Avatar
SIXFOOTER
this is what I am doing
Old Aug 24, 2007 | 10:32 PM
...Roger...'s Avatar
...Roger...
Can you double flair it ?Would that solve it.I'm not sure exactly what your doing.
Old Aug 24, 2007 | 11:24 PM
chris75stingray's Avatar
chris75stingray
i think you can get 1/4 to 4an then 4an to 6 an
Old Aug 24, 2007 | 11:28 PM
noonie's Avatar
noonie
Cheap way is to silver solder a 3/8 over the 1/4 line.
There was a comprehensive thread about this fitting about a year ago. Maybe a search will be lucky.
You might want to try this free prog for annotating pics. My eyes aren't what they used to be
http://www.getpaint.net/
Old Aug 25, 2007 | 12:33 AM
SIXFOOTER's Avatar
SIXFOOTER
Thanks for the link Noonie. I thought about Silver Soldering the thing on there, might be the way to go. Problm is the line is steel and the fitting aluminum.
There is got to be a way to get this done. Anyone know what the fitting is in the PS valve input side? I never understood that flair, inverted flair thing..
Will a pipe thread or an o-ring fitting thread into the valve?
Old Aug 25, 2007 | 01:06 AM
7T1vette's Avatar
7T1vette
Why not weld/braze/silver solder a piece of 3/8" line to the end of the 1/4" line. Then flare the 3/8" for the AN#6 fitting.
Old Aug 25, 2007 | 07:45 AM
SIXFOOTER's Avatar
SIXFOOTER
There is an idea
Old Aug 25, 2007 | 07:48 AM
...Roger...
Wouldnt a standard 5/16 brake line thread in there?
Old Aug 25, 2007 | 08:08 AM
SIXFOOTER's Avatar
SIXFOOTER
dunno, its 1/4" tube, this is the high pressure IN on the PSC valve
Old Aug 25, 2007 | 08:27 AM
jnb5101's Avatar
jnb5101
six
check out aeroquip at 2600 west sample 954-973-5900.
jeff
Old Aug 25, 2007 | 08:46 AM
...Roger...
Sorry I meant 1/4
Old Aug 25, 2007 | 10:24 AM
noonie's Avatar
noonie
That's what I meant.
Slip the 1/4" inside the 3/8" about a 1/2 " and then silver sweat it.
You can also go to hydraulic fittings which are steel and also 37° same as -an if you want to direst braze, but you do need an overlap for strenght.
Old Aug 25, 2007 | 04:26 PM
SIXFOOTER's Avatar
SIXFOOTER
Originally Posted by jnb5101
six
jeff
Ahhh, that was the ticket
1/4" sleeve, nut and a 4 to 6 adapter, good to go.
Thanks Jeff
To line adapter needed
