Need stuckscrews help...please save me
Old Aug 28, 2007 | 10:27 AM
mod81's Avatar
mod81
Default Need stuckscrews help...please save me
So I refinished my rocker panels the other day, however the screws were so stuck in place neither my arm, nor drill could budge them. I ended up drilling about 3 of them out until the head of the screw popped off and I could get the panel off. Well now I need to put them back on and have a headless screw sticking out of the car. Any ideas or tricks to get the originals out?
Old Aug 28, 2007 | 10:40 AM
69monzacpe's Avatar
69monzacpe
Get some Nuts Off spray and spray them, let them soak, and do it a few times. Tap on the end of the screw with a small hammer (light taps) between soakings to help get the stuff in the threads. Then get some locking pliers, clamp on to what's left of the screw and CAREFULLY unscrew. Take your time.
If that doesn't work, trim the screws flush to the surface (dremel cut off wheel should work great), then drill out the screw. Be sure to use a drill the diameter of the INSIDE of the threads, not the OUTSIDE of the threads. Also, you will probably want to put a dimple in the end of the screw with a nail set to keep the drill from wandering at the start. Once you have drilled them out, use a tap that matches the original thread size and carefully tap out the hole.
Good luck, be patient and you can "git-r-done!"
Old Aug 28, 2007 | 10:42 AM
big_G's Avatar
big_G
Center punch the remains, use a good drill bit and tap set for 10-24 thread screws. Home Depot and Lowes sell the kits. G/L and take your time. Don't forget the safety glasses....
Old Aug 28, 2007 | 12:13 PM
Stewart's74's Avatar
Stewart's74
I had to drill mine completely out. I re-tapped the holes and used new screws. It was a PITA.
Old Aug 28, 2007 | 12:18 PM
bluesilver82's Avatar
bluesilver82
I drilled all of mine out. I replaced them with OEM screws and instead of tapping them I just put a nut on the back of them with a lock washer. I think they are threaded 8/32 but im not sure. Took me about an 1 hour to do the reinstallation.
Old Aug 28, 2007 | 01:22 PM
mod81's Avatar
mod81
can you get to the back of all the screws easily...I didn't jack it up to take them off but it seemed pretty tight
Old Aug 28, 2007 | 02:23 PM
Red 69's Avatar
Red 69
This is another option offered by Ecklers. Cost about $16.
Of course, you could just use a nut on the back after drilling out the screw, as already suggested. You could epoxy the nut on the back side to keep from losing it. Yes, there is plenty of room on the back side to work it. Put some anti-seize on the screws before replacing them.
Old Aug 28, 2007 | 04:20 PM
S489's Avatar
S489
consider using SS screws for reinstallation; i got tired of "blackened" CS screws rusting up the works. can touch up the heads with black out paint - looks the same . . .
Old Aug 28, 2007 | 05:02 PM
VCuomo's Avatar
VCuomo
That's what I did, except I didn't paint the new screws - they're stainless, so they won't rust, and they look good (IMHO).
And that $16 kit from Ecklers? ROFLMAO - should cost you about $3 at your local Ace Hardware (or Home Depot, or Lowes, or ...).
Old Aug 28, 2007 | 05:14 PM
Scott Marzahl's Avatar
Scott Marzahl
I ground mine off from the backside, epoxied on some new T-nuts and used stainless screws.
Old Aug 28, 2007 | 06:13 PM
7T1vette's Avatar
7T1vette
He's got the right idea. This is actually an improvement over the original design while keeping the initial design intent. I've replaced a couple of the more damaged T-nuts with this method and it works great.
Old Aug 29, 2007 | 09:35 AM
bluesilver82
I used needle nose plyers to hold the nuts on the backside. hmmmm that does not sound quite right. lol anyway you know what I mean.
To Need stuckscrews help...please save me
