Retard and advance.
Old Aug 30, 2007 | 08:39 AM
Block_Head's Avatar
Block_Head
Default Retard and advance.
If you are standing on the driver's side of the engine bay, with the hood open, looking at the distributor, which way is retard and which way is advance?
Fill in the blanks.
Clockwise - ???
C-Clockwise - ???
Also, I have heard that retarding timing can make the engine overheat or heat up too fast. Is this true?
Old Aug 30, 2007 | 08:44 AM
bondoboy's Avatar
bondoboy
Turning the distributor housing counterclockwise would advance your initial timing, since your distributor shaft spins clockwise.
Old Aug 30, 2007 | 09:06 AM
Block_Head's Avatar
Block_Head
Is it just me or is grasping the whole timing thing way over my head?
I do not understand at all how to tell degree when timing, let alone plan for 36 of them.
[Bangs head]
Old Aug 30, 2007 | 11:29 AM
Bob Onit's Avatar
Bob Onit
[Bangs head]
Having an adjustable (dial back) timing light makes setting 36* or any other number of * just as easy as setting the initial timing.
If you buy a dial back light be sure to get one that reads RPM as well. With this type of light you can dial in your timing in about 60 seconds providing your vacuum advance unit is capable of reaching 36*
If not, then you need to do some work on the distributor.
Old Aug 30, 2007 | 11:44 AM
justanotherdoe's Avatar
justanotherdoe
Do you have a timing light?
The idea is to use the strobe effect to see where a mark on the harmonic balancer aligns to the tab on the engine block when #1 cylinder fires. The tab has a 0 reference, and so the mark appearing 'before' the reference is advance, the mark apperaing 'after' is retard, keeping in mind the direction of engine rotation.
Two ways to determine the 36 degrees. First is to use a timing light with an adjustment **** that allows you to 'dial in' the 36 degrees and look for the flash to align the mark and 0 reference; the other is to mark the harmonic balancer a second time 36 degrees from the default mark and align this to the 0 reference.
Old Aug 30, 2007 | 12:12 PM
Block_Head's Avatar
Block_Head
Okay I'm starting to see the light here.
I need a dial back light.
What gets me is, if 36 before is what's best, why do they not make the 0 mark on the balancer and 36 before the same thing? Wouldn't that make it all very easy?
Old Aug 30, 2007 | 12:33 PM
Vette Crazzy's Avatar
Vette Crazzy
using an adjustable timing light. mark your zero on the balancer and mark the zero on the timing tab. set the dial on the timing light to 36, rev the engine to 3000 rpm and turn the dist until the marks line up and you are done
vc
Old Aug 30, 2007 | 12:37 PM
Block_Head's Avatar
Block_Head
vc
Sounds very simple. Thanks.
Is there something I have to do before I set that 36? Something with the vacuum hose disconnected?
Old Aug 30, 2007 | 08:53 PM
chris75stingray's Avatar
chris75stingray
vc
you will want to also make sure that the advance springs are maxed out by that rpm or else the timing will be over 36 at higher rpm
Old Aug 31, 2007 | 12:44 AM
7T1vette's Avatar
7T1vette
You need to download Lar's timing papers and read them thoroughly before doing it. His papers are very informative and easy to read. You will have a good understanding of what you are doing after reading them.
Old Aug 31, 2007 | 07:48 AM
Block_Head's Avatar
Block_Head
How do you do that? You have to have the cap on to do this timing thing, and last I checked you can't see the springs with the cap on.
Old Aug 31, 2007 | 07:49 AM
Vette Crazzy
the springs will be maxed out by then. run it up to 3500 rpm and set it just to be sure
vc
Old Aug 31, 2007 | 08:14 AM
Block_Head's Avatar
Block_Head
vc
Okay, got it.
Are there any steps I need to take before I set it to 36 using a dial back light at 3500 RPMs?
Does anyone have a copy of Lars' paper they wouldn't mind sending me?
Old Aug 31, 2007 | 09:27 AM
dmaaero's Avatar
dmaaero
Barry has them on his web site, you"ll find a link to them and a lot more usefull info here:
http://forums.corvetteforum.com/show....php?t=1430339
lars's Avatar
lars
Most of my papers floating around the Internet are not current copies. E-mail me for the latest revision and current copy:
V8FastCars@msn.com
Specify that you need the timing paper since I have a lot of different papers available.
Lars
Old Aug 31, 2007 | 09:37 AM
Block_Head's Avatar
Block_Head
V8FastCars@msn.com
Lars
Email sent, thanks.
To Retard and advance.
