Probable Cause?
Old Aug 31, 2007 | 08:31 PM
Busrydr's Avatar
Busrydr
Default Probable Cause?
I have a 73 SB that has been converted to a stock 75 HEI dristributor. There is a sound that appears to be coming from the top of my engine that sounds like a bearing begining to fail. My best guess would be that this is coming from the distributor.
I've torn into just every other part of the car but zero experience with distributors.
Any suggestions on checking to see if the issue is the distributor? What should I look for? What type of effort to replace/repair? The performance has been outstanding for some years now. What tuning concerns will I have by removing, repairing and replacing if the distributor is the problem?
Old Aug 31, 2007 | 08:40 PM
sjmaster's Avatar
sjmaster
They are not complicated. Just mark the position of the rotor (I make a large cardboard template with cutout for rotor, reference four points, like the air cleaner bolt, back fire wall etc.) remove the hold down and pull her out. Inspect the drive gear and bushings (I think they have bushing, not bearings) for play. When reinstalling, use your template to set rotor posisition and drop into place. Make sure you don't crank the engine over and loose the reference.
Old Sep 1, 2007 | 02:32 AM
Busrydr's Avatar
Busrydr
Thanks, that helps. Sounds easy enough. I'll see what I can find on replacing the bushings.
Old Sep 1, 2007 | 09:56 AM
croaker's Avatar
croaker
before tearing into everything take a long screwdriver or a mechanic's stethoscope and hold the screwdriver or scope to your ear and put it on the housings for the alternator and other items could be the alternator water pump or something else
Old Sep 1, 2007 | 06:40 PM
Busrydr's Avatar
Busrydr
A mechanic's stethoscope. I always wanted one of those for my tool box. Now I have a good reason to buy it. Excellent idea.
Thanks.
Old Sep 1, 2007 | 07:28 PM
Les 94 Comp Yellow's Avatar
Les 94 Comp Yellow
A really loooong screwdriver works just as good and you also get a really loooong screwdriver for the tool box as a side plus.
Old Sep 1, 2007 | 07:40 PM
ghoastrider1's Avatar
ghoastrider1
check the alternator, water pump and anything else the belts are hooked to. Find the sourse of the noise before unbolting stuff.
Old Sep 1, 2007 | 09:02 PM
RMS73's Avatar
RMS73
most distributors don't have bearing they have bushings. If a bushing is worn badly then you should be able to feel movement in the rotor atop the distributor shaft. Usually bushings won't be noisey. Noisey is usually an alternator. A bad bearing in the water pump means the water pump seal may be leaking water or will be shortly. A water pump bearing would be very hard to hear due to the fan noise.
My first choice would be an alternator going bad.
Roger
Old Sep 2, 2007 | 07:11 AM
kb2fzq's Avatar
kb2fzq
Easy first......difficult later
Old Sep 2, 2007 | 10:30 AM
Busrydr's Avatar
Busrydr
But that would take the fun out of buying a new tool and looking like Dr. Rebuild when working on my car
You guys have some great input. It helps to have second opinions when your first thought sometimes cloud your judgement. Come to think about it, I know the sound of a water pump going bad and this sure is a good match.
I'll post up the results.
Thanks,
Dr. Busrydr
Old Sep 2, 2007 | 10:47 AM
7T1vette's Avatar
7T1vette
Loosen or remove one accessory belt at a time {if you can}, to see if one of the accessory components is causing the noise. The other alternative is the fuel pump [but it won't make a bearing-rattle noise]. I can't imagine a bearing-like noise in the distributor, unless it's a problem with the tach drive gearing or just a tach drive cable problem.
Old Sep 2, 2007 | 03:46 PM
Busrydr's Avatar
Busrydr
My car was just picked up to go for paint. So it will be a few weeks unless I go there and do some work on it.
But I listened again this morning with just my ears and the sound does really appear to be coming from the distributor area.
Louder on accel and contant on idle. I'll get to the bottom (or top) of it before anything major happens.
To Probable Cause?
