Front Suspension Shields
Old Sep 2, 2007 | 01:10 AM
stinger12's Avatar
stinger12
Default Front Suspension Shields
Is it really necessary to have these tabs on the front splash shields? I understand they are supposed to be bent up once the bolt is installed, but do I really need them? The reason I am asking is that they are $30 each and mine are in perfect condition, minus the fact that these tabs are missing. I replaced my 2 rear ones because they were all bent, but these ones are in perfect condition. Both shields are only missing one of the two tabs.
Old Sep 2, 2007 | 07:57 AM
stinger12's Avatar
stinger12
bump
Old Sep 2, 2007 | 08:15 AM
Green73's Avatar
Green73
I wouldn't worry about it. If your concerned that the bolt will back itself off, use a lock washer. Otherwise, I'd just use the one tab thats there.
Old Sep 2, 2007 | 08:55 AM
stinger12's Avatar
stinger12
Thanks for the response. I've decided to use them and save myself $60.
Old Sep 3, 2007 | 01:37 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Use some blue locktite and whats left of the tabs, you should be fine.
Old Sep 3, 2007 | 01:52 AM
babbah's Avatar
babbah
I have these on my 67, Considering the fact that the large bolt that goes onto the tabbed hole is torqued at over 100 lbs. into the front spindles I don't think you need to worry about this bolt ever coming loose. Keep yours!!
Old Sep 3, 2007 | 02:13 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Absolutely
To Front Suspension Shields
