vent cable locations
Old Sep 2, 2007 | 11:22 AM
ace_cobra's Avatar
ace_cobra
Default vent cable locations
if was hooking up my centre console on my 70 stingray and i only have 3 vent cables and im pretty sure that there are supposed to be 4. If someone could shed some light on the routing of the cables. i have the 2 side vent cables and one coming from behind the radio, but i dont know where the other one is, or if there is another one?
Old Sep 2, 2007 | 11:54 AM
Busrydr's Avatar
Busrydr
If I'm not mistaken there are only 3. The left and right side vents controlled by the levers and one cable to control a door on the heater box with is controlled by the thumb wheel.
But again, I may be mistaken.
Old Sep 2, 2007 | 12:15 PM
ace_cobra's Avatar
ace_cobra
what connects to the other thumb wheel?
Old Sep 2, 2007 | 02:29 PM
70Donnybrooke's Avatar
70Donnybrooke
The other one is vacuum operated. It is a big plug that has several hoses coming out of it to work the HVAC.
Old Sep 2, 2007 | 02:59 PM
Busrydr's Avatar
Busrydr
I would be guessing if I said for certain. I just removed my unit to install the Hot Rod Air. I haven't put it back in yet. But I know that one cable was connected to the thumb wheel mechanism. Had to pop off the little washer like keeps to free the cable.
On the right wheel, there is a vacuum control for the rear deck vents. The left thumb wheel I believe has the 4 hose vacuum pod. The 3rd cable connects to the arm of one of the thumb wheels. I am almost certain it connects to the heater box. All other doors are vacuum operated.
Old Sep 2, 2007 | 03:37 PM
Busrydr's Avatar
Busrydr
Based on the AIM for my 73 that was a Non-A/C car, it looks like the 3rd cable connects to the right thumb wheel and the other end connects to the heater box to control the defrost diverter door.
It does route from the right thumb wheel towards the radio and then bends to the right to connect to the assm on the heater box.
Old Sep 2, 2007 | 03:42 PM
ace_cobra's Avatar
ace_cobra
ok so what connects to the left wheel?
Old Sep 2, 2007 | 06:51 PM
Theiskell's Avatar
Theiskell
I have a 69 but I am pretty sure yours is the same. The left wheel if you look at your heater assy moves a vacuum switch that a 4 port round vacuum connection attaches to. The previous posts are correct in regards to the 3 cables, I just went through all of this on mine. Hope this helps
Old Sep 2, 2007 | 07:37 PM
ace_cobra's Avatar
ace_cobra
ok and what do the cable anchors bolt to? By anchors i mean the hard plastic peices that keep the other cable from moving and allowing just the inner cable to move
Old Sep 2, 2007 | 07:46 PM
Theiskell's Avatar
Theiskell
Not sure if this is correct but mine were on the posts that the front fiber optics cover uses to bolt to the console. The 7/16 nut was holding the cover on then the tab for the cable was on and then a clip to hold it all together. I am not sure that was English but I understood did you.
Old Sep 2, 2007 | 09:19 PM
ace_cobra's Avatar
ace_cobra
do you mean the fibre optics trim plate? and what about the thumb wheel cable, what does it tie to?
Old Sep 2, 2007 | 10:01 PM
Theiskell's Avatar
Theiskell
Yes the trim plate.....not sure on the thumb wheel.... hook it to the post and see what it lies up with there cant be much in that area..
Old Sep 2, 2007 | 11:44 PM
Busrydr's Avatar
Busrydr
The right thumb wheel arm (for lack of a better word) has a little 1/4 vertical stub. The cable attaches to this and is held in place with a spring type washer (the perforated washer thingy) that is actaully a press-on nut. The cable has a black plastic mounting tab atthe thumb control end that attaches to the right bracket of the control unit. The other end attaches to the heater box.
I don't have pictures because all my stuff is ripped out. But if you're still unsure I can pull out the box and snap some pics.
Old Sep 3, 2007 | 12:26 AM
ace_cobra's Avatar
ace_cobra
no thats ok, i think i will be able to manage. Im going to try and reassemble console tomorrow and hope for the best
To vent cable locations
