q-jet fast idle adjust
Old Sep 4, 2007 | 07:30 PM
early71's Avatar
early71
Default q-jet fast idle adjust
got '71 s/b running sweet,with exception of start-up speed.I found adjust screw on pass.side of carb, under linkage.Since I messed w/it,engine races high and I kick it down,knocking off fast idle adjust too soon.Sounds like simple adjust,any gurus care to opine?? JC
Old Sep 4, 2007 | 08:23 PM
BigBlockk's Avatar
BigBlockk
Sounds like you found the fast idle adjusting screw. The next time you start it up from cold look at the RPM and adjust it to about 1400 before you kick it down. Drive off normally.
BigBlockk
Later.....
Old Sep 4, 2007 | 10:14 PM
lars's Avatar
lars
As Ralph says, just adjust it to where you want it. I like mine a little lower than he does, and set mine at about 1100. I think spec is in the 1250-range.
To q-jet fast idle adjust
