*Power Window Help*
Old Sep 5, 2007 | 11:19 PM
SILVERSIXX's Avatar
SILVERSIXX
Default *Power Window Help*
Just a quick question before I tackle the drivers side power window.
I noticed that the needle on the ammeter moves when I push the window switch up, but nothing when I push for the window to go down. Is it possible that it's only the switch?
Old Sep 6, 2007 | 04:17 AM
agent kronus's Avatar
agent kronus
I noticed the very same thing, I took out motor tested on the battery with a 2 wires, working fine, the shaft that sits in the backing plate that holds the motor in, was rusted in there, got it off, got the rust of, greased in all up, works fine now
dave
Old Sep 6, 2007 | 07:28 AM
...Roger...'s Avatar
...Roger...
Yes-very poss. its the switch.Could also be the wire broke in the rubber boot between the body and door.Try when pushing on switch also push down or in -if that works replace the switch.
To *Power Window Help*
