I have a 81 vette. The AC system needs charging and I was at a local unclaimed freight sell when I came across a 15 lb bottle of R-12 which I bought from them for $20
I then went to my nearest pawn shop and bought the gauges for the recharge process. Now all I need to know is how much pressure should I have on the low side and the high side so I dont over or under charge my system? Thanks!
Once you have it vacuated and verified it holds vacuume.
Look on the sticker on the evap box, it will tell you how many lbs it takes. Connect the bottle with it on an ACCURITE scale, do the math.
Easy
Hmmm, Contaband material and stolen gauges, this is starting out right wouldnt ya say? Pressures are determined by the outside temperature. There is no real solid figure for that. There should be a tag with the amount stated on it. I dont have information here, but about 3 lbs. will be close.
