1968 TriPower
Old Sep 12, 2007 | 06:09 PM
Lilfur's Avatar
Lilfur
Default 1968 TriPower
I have a 1968 427, that ahd been convertedto a dual quad set up with a electric fuel pump. I have found a original tripower from a 68 that I would like to install. Does anyone know if I could still use the electric fuel pump with this set up ??
Old Sep 12, 2007 | 07:19 PM
RPOL68's Avatar
RPOL68
There would be no reason why you couldn't. Tri-power cars came with only one fuel feed line (no return). The original setup had metal lines from the fuel pump to the carbs. Just be sure you use a fuel pump cutout in case of a collision.
Old Sep 12, 2007 | 07:34 PM
7T1vette's Avatar
7T1vette
Regulate fuel pressure down to a level the carbs can live with (maybe it already is).
To 1968 TriPower
