Crazy Idea?
Old Sep 14, 2007 | 07:07 PM
jtg700's Avatar
jtg700
Default Crazy Idea?
Hello. The top corners of my hood (1980) are about 1/2 higher than the quarter panels. I know the Corvette is notorious for poor fit/finish, especially the older ones, but this is a lot. While explaining this problem to a friend, he told me that it is possible to slightly "bend" the hood corners through a process that included applying heat to the underside of the hood at those spots. This seems highly suspicious to me, as I've never heard of this as a way to fix fiberglass. Is there any truth to it, or is he crazy (as usual!) Everybody is an expert! Thanks! JG700
Old Sep 14, 2007 | 07:28 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Yup crazy idea, adjust the hinges, hood latches and bumpers
Old Sep 14, 2007 | 08:35 PM
Tim H's Avatar
Tim H
How do you know there higher than the 1/4s???
Also there are spacers on the hood release brackets that are attatched to the hood.
Old Sep 14, 2007 | 08:49 PM
chris75stingray's Avatar
chris75stingray
does the whole hood gradually go up from the front to back? or is the hieght good up untill the end, then the corner just kicks up?
Old Sep 14, 2007 | 08:52 PM
kayosnes's Avatar
kayosnes
when i got my new l-88 hood, it seemed like i had the same problem. But i played around with shims under the hinges, and the release mecanism for the hood. And got it even in the end. Trye everyting else.,before starting work on the fiberglass
Old Sep 14, 2007 | 11:28 PM
jtg700's Avatar
jtg700
The hood is pretty even all the way up until the corners, which then flare up. How do you adjust the latch?
Old Sep 15, 2007 | 12:29 AM
7T1vette's Avatar
7T1vette
First thing to do is to buy a service manual and/or assembly instruction manual (AIM) on your car. Then you read the stuff about adjusting the hood. Then you try it. By the way...if your hood is a GM hood, and it's from the same year as your car, I'd bet a lot that it will adjust properly. If it's an aftermarket hood, all bet's are off.
Old Sep 15, 2007 | 10:06 PM
kayosnes's Avatar
kayosnes
All corners?
Old Sep 15, 2007 | 10:37 PM
VettePower's Avatar
VettePower
[QUOTE=jtg700;1561918215]While explaining this problem to a friend, he told me that it is possible to slightly "bend" the hood corners through a process that included applying heat to the underside of the hood at those spots.
Old Sep 15, 2007 | 11:36 PM
rihwoods's Avatar
rihwoods
[QUOTE=VettePower;1561930829]
Old Sep 15, 2007 | 11:48 PM
mrvette's Avatar
mrvette
Actually the guy is correct, just that it WILL take the paint off ....too high a temp.....
Old Sep 15, 2007 | 11:52 PM
VettePower's Avatar
VettePower
It still is the most ridiculous thing I have ever heard of......
Old Sep 15, 2007 | 11:57 PM
mrvette's Avatar
mrvette
WHY?? i'ts still plastic, even with glass in it....it still will mold and form when hot enough.....just like plastic castings or air sucked down vinyl dashes...etc.....it will melt and burn even....
Old Sep 16, 2007 | 12:44 AM
7T1vette's Avatar
7T1vette
The 'plastic' the C3 hood was made of is a curing, thermo-setting material. Once it takes a set (during production) you can't bend it much (without breaking it). If that were not true, all C3 hoods would be warped from 30 years of engine heat!
To Crazy Idea?
