horn button
Old Sep 14, 2007 | 11:21 PM
corvetteed2shark's Avatar
corvetteed2shark
Default horn button
I did a total body off restoration on my 75 vert and I know this sounds stupid but I can't for the life of me get the damn horn button back on I know it is just supposed to snap back in but it doesen't this is a standard column car
any suggestions would be appreciated and yes I am ready for all the razzing that I deserve
Old Sep 15, 2007 | 12:38 AM
7T1vette's Avatar
7T1vette
First, disconnect the battery [so you can work on it and not hear the horn or short something out]. You can look at the spring-clip ring gizmo and see how it is supposed to go together. If you see some obvious interference problem, resolve that first [including getting the column parts assembled properly to begin with. If it looks like it should go on, set it in place (centered and flat...not cockeyed), then pop it with the heel of your palm...not hard, but firmly. If it starts to go in but comes back out, pop it a little harder. It should go on. If either part of the attaching ring is new, the problem is likely a difference in design from the original part.
Old Sep 16, 2007 | 09:29 PM
65GGvert's Avatar
65GGvert
The rings on the horn button just snap over the fingers on the contact ring. It sounds like either the horn button ring is bent or broken, or the contact ring is bent or too low. There should have been some spacer rings that raised the contact ring up enough to snap the button on. If you left the spacer rings out, the contact ring may be so low down in the wheel space that the rings can't overlap. Mine had three identical spacer rings with three screw holes that line up with the holes in the steering wheel. Without the spacers, the horn button wouldn't reach far enough onto the springy insulated contact ring to attach. Post what you find.
To horn button
