bondo inside door pillar
Old Sep 16, 2007 | 02:42 PM
phil w's Avatar
phil w
Default bondo inside door pillar
Hello My 77 Has what looks like bondo inside both door pillars,just below the window frame. It is smooth and about 5 inches long and 1 and a half wide. I see this on some pictures of other vettes.Is this factory or a repair ? I would appreciate if anybody knows Thanks Phil
e-mail fortapachephil@yahoo.com
Old Sep 16, 2007 | 03:42 PM
mrvette's Avatar
mrvette
see if it's soft or very hard....lotsa epoxy looks like bondo...but bondo never gets THAT hard....
need a pix to see for sure just what/where...but there is lotsa glues down in that area gluing the fenders to the steel....or for that matter in the firewall area/window well......but from behind the kick panel, in that steel hinge area there should be none visible.....
Old Sep 16, 2007 | 03:51 PM
Alan 71's Avatar
Alan 71
I'm not sure just where you're referring to, but there is a small amount of filler (not Bondo) on the hinge pillar which is used to smooth the joint between the steel pillar and the fiberglass inner fender filler panel that is pop riveted to the to the hinge pillar.
Boy... that's some confusing sentence, but it is what I think you're asking about.
Regards,
Alan
Old Sep 17, 2007 | 06:16 AM
phil w's Avatar
phil w
Default bondo on door pillar
Hi Thanks for the response I'll try to post a picture. Not sure how to do that yet. Thefiller is very hard like steel.
Old Sep 17, 2007 | 01:29 PM
1Z87L8's Avatar
1Z87L8
sounds like the factory seam sealer to me
To bondo inside door pillar
