72 wiper door, keep it or delete it?
I found the change over to a linear motor....mini screw jack setup with my own relay controll setup was mucho better/more reliable than that old vac thing....
Eddie
Eddie
Speaking of clean lines, and this isn't intended to offend ANYONE, but how in the name of all that is slick, do people think that removing the popup headlight assemblies on these cars only to replace them with some type of recessed retangular headlight bucket type thing and consider it an improvement
is beyond me.Rant over
Saved weight, binned the vacuum worked out good for me
Eddie
VERY SIMPLE.....they WORK!!!.....in the first 3 years of ownership, I replaced both witches hats, and redid the entire vac hose rerouting thing no less then twice, the vacuum canister was a squareed off mini gas tank looking thing on the driver's fender liner, it had fractured from metal fatiguw and so was unfixable and full of leaks....none to be found, run the system without it...fine, worked ok....did ALL the typical parts, as well as every damn part in the vacuum operated wiper door....it's a '72......
so finally when hitting a small florida deer, about the size of a Great Dane or so....it took out both headlights....so in went the Ecklers sugar scoops, since altered with lo profile camaro bulbs....
the total lack of reliable replacement parts is what made the vac system inoperable/unreliable so many times, if it wasn't the vac switch it was the vac solenoid, if not that it was someother damn thing, if not that it was yet another witches hat.....then a canister would stick closed...blew it open with air jet...that type crap....the canister were allready NEW when I got the car....nice bright shiney metal anyway...
69myway, Chris, gave me a linear actuator...mini screw jack, I had to fix it, and then installed with my own relay controller to operate with my intermittant WSW control system....works like factor intended now...
I blame all the vac unreliability on basically crappy aftermarket parts....
some of which are not available....like that WSW vac solenoid to open the door up under the behind the tach....
besides, it looks better, more modern rendition of a classis design that has been mimicked around the world....trend setting car, that now is a bit updated, not longer having those stupid looking bug eyes opening one at a time, sometimes not at all....
or worse yet....about 1/2 way open....
was'nt any problem FIXING it.....problem was fixing every damn problem in succession, and then having to do it yet again just for grins....a couple years later....
too boot those assys are worth maybe 40 lbs each....chop easy 60 lbs off front end for the change....
Maybe you can tell us what does not work correctly (we need specifics in order to diagnose it) and we could offer insight and repair advice.
GM guys did what they could cheep as possible for the times....but times change, and so I see NO excuse modern tech can't be done to improve old cars.....for to do so would make a T bucket start with a crank.....
