dist shaft
Old Sep 20, 2007 | 09:03 AM
blue by you's Avatar
blue by you
Default dist shaft
Been awhile since any posts. I've been out of work all summer so money was tight. Now that I'm working I can spend some money. How hard is it to replace the dist shaft on a stock gm dist in a 71 sb.Gerry
Old Sep 20, 2007 | 09:11 AM
pws69's Avatar
pws69
Pretty straight forward. Remove the tach drive stuff by unscrewing the piece the cable attached to. Then, knock the roll pin out of the drive gear with a small drift and pull the gear off. Pull the shaft out. Don't loose the spacer washers and make sure you set it up with the proper end play.
Old Sep 20, 2007 | 09:53 AM
vettfixr's Avatar
vettfixr
One other thing. When you reinstall the gear to the bottom of the shaft make sure the dimple on the gear points the same way the rotor points or your phasing will be off.
Old Sep 20, 2007 | 09:54 AM
pws69's Avatar
pws69
Excellent point - I hadn't had my coffee yet!
Old Sep 20, 2007 | 01:06 PM
Stewart's74's Avatar
Stewart's74
I think Lars has posted a Tech Article on this No?
Either here or on corvettefaq..
Stu
Old Sep 20, 2007 | 03:20 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
See if you need a new shaft or maybe new bushings. Probably going to want to replace the bushings anyway. Just get some new bushings and the tool.
Old Sep 20, 2007 | 03:27 PM
7T1vette's Avatar
7T1vette
The bushings in the housing bore should wear before the [hardened steel] shaft would have any wear problems. If the shaft is damaged, then replace it...if not, replace the bushings and any other worn components.
Old Sep 20, 2007 | 03:31 PM
Mikef714's Avatar
Mikef714
If the phasing were off, how would engine performance be affected?
Old Sep 20, 2007 | 04:11 PM
blue by you
Thanks guys for all of input, I need to replace the shaft due to the gear for the tach drive is shot, maybe I'll order the bushing also and do it right. Gerry
Old Sep 20, 2007 | 07:26 PM
7T1vette's Avatar
7T1vette
Mikef714.... I've not heard the term "phasing", but the dist. drive gear has an ODD number of teeth [11 teeth], so when you install the gear 180 deg from original design, the timing will be off by about 15 deg [1/2 of a gear tooth] from where you left it. If that's "out of phase", so be it.
Old Sep 20, 2007 | 10:00 PM
Mikef714's Avatar
Mikef714
I now understand; thanks
Old Sep 21, 2007 | 07:36 AM
vettfixr's Avatar
vettfixr
This is from MSD's website
ROTOR PHASING
Rotor Phasing is defined as the alignment between the rotor tip and the distributor cap terminal when the spark occurs. This position can be very important to your engine's performance. If the alignment is incorrect, the spark will jump to the next closest terminal or another ground resulting in a misfire and loss of power.Since the timing is going to be controlled
http://www.msdignition.com/pdf/2005/frm27402_23451.pdf
To dist shaft
