Brake bleeding question
Old Sep 27, 2007 | 03:15 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Originally Posted by 7t6vette
Z-man, I heard a rumor that the spring loader pressure bleeder valves get stuck after 1st use. Fact or Fiction? Plus don't you have to keep adding break fluid to the MS and pump the breaks to keep pressure built up? As for the pressure bleeder I agree that cap that mounts to the MS could be a better design. I like the thought of using the original MS cover (modified).
Utter fiction. I've never had one stick. Sounds like someone who was too cheap to buy the speedbleeders and was trying to justify the decision.
Old Dec 24, 2007 | 04:15 PM
rayluka's Avatar
rayluka
Originally Posted by Z-man
The rears have inside and outside bleeders.
Forget all those expensive bleeding systems - get a few speed bleeders and be done with it. It takes about 1 minute per wheel to bleed them - singlehandedly.
Which model fit?
