Check Engine Light
Old Sep 22, 2007 | 10:12 AM
biaggio's Avatar
biaggio
Default Check Engine Light
I have a 1982 corvette. The Check Engine Light came on briefly for a few seconds and then went off while driving. Any suggestions or comments would be appreciated. Thanks
Biaggio
Old Sep 22, 2007 | 10:23 AM
...Roger...'s Avatar
...Roger...
It logged a code.
Old Sep 22, 2007 | 03:31 PM
Shirley1978's Avatar
Shirley1978
it felt sick so it checked the light on, but then it realized it was just gas and decided it was just fine..
Old Sep 22, 2007 | 04:59 PM
wnmech's Avatar
wnmech
Like DWncchs said see if it logged a code. You need to look under the drivers side of your dashboard and look for the computer diagnostic connector. It will be somewhere usually accessable without removing any panels. It is a 2 row connector. Look for the letters A & B. The A will be the ground and the B will the diagnostic. You take either a paperclip or a wire and ground the A to The B and then turn the ignition to the on position. You will read the codes by the Check Engine light flashing. The check engine light will flash a code 12 three times. That means a single flash followed by a double flash. After that it will flash out the trouble codes by the same series of light flashes. For example if it flashes twice and then pauses with four flashes that would be a code 24. After the computer is done flashing the trouble codes it will go back to the original flashing the code 12 again. Let us know what trouble codes you have logged. To clear the codes either pull the ECM fuse or disconnect the battery.
Old Sep 22, 2007 | 06:08 PM
wombvette's Avatar
wombvette
82 connector should be under the ash tray.
Old Sep 22, 2007 | 06:23 PM
7T1vette's Avatar
7T1vette
If it did not log a code, it may have experienced an "out of normal range" operating condition. When an engine sensor starts to fail or "changes its behavior", the engine light can come on...but go out again if that system goes back to operating normally. You might have a sensor starting to go. If there is no registered code, and the light doesn't come back on, ignore it. If a code is logged, that may give you some idea of what is starting to fail.
Old Sep 22, 2007 | 08:32 PM
biaggio's Avatar
biaggio
Thanks to all!!!!
Old Sep 22, 2007 | 09:00 PM
Richard Cooper's Avatar
Richard Cooper
if you are out driving around one of these beautiful weekend days and end up anywhere near New Paltz, stop in and we will check it out.
To Check Engine Light
