Help with Exhaust Manifold Decode
Old Sep 23, 2007 | 09:12 PM
98IndyPacer's Avatar
98IndyPacer
Default Help with Exhaust Manifold Decode
I cracked the left side exhaust manifold while installing a new chambered exhaust system. I need to find a replacement with the correct casting/date code. The car was built the last few days of production in July, 1972. The exhaust manifolds on both sides of the engine are casting number 3932461. Below the casting number is RH5 and E31 is on the back side of the manifold.
What does the RH5 stand for?
What does E31 mean?
Thanks, Ed
Old Sep 23, 2007 | 10:01 PM
LYLE's Avatar
LYLE
What does E31 mean?
Thanks, Ed
RH5 was the mold number
E31 is May 31 Exhaust manifolds have no year only month and day
Old Sep 23, 2007 | 10:11 PM
98IndyPacer
Lyle: Thanks for the info.
The date code is on the back side of the manifold and not visible when installed. So to "look" correct I just need to find a manifold with the same casting number and any mold number??
Thanks, Ed
Old Sep 24, 2007 | 09:02 AM
LYLE's Avatar
LYLE
That date can be read so if that is important to you find one close to the original date.
To Help with Exhaust Manifold Decode
