Finding a short
Old Sep 26, 2007 | 09:27 PM
kona's Avatar
kona
Default Finding a short
I defintely have a dead short somewhere. New battery fully charged and within about five hours of sitting it is completely dead. Did the Bubba thing and installed a cutoff at the battery.
Can anyone tell me how to find a short in the system? Is there a good technique?
Kona 1980
Old Sep 26, 2007 | 09:30 PM
Durango_Boy's Avatar
Durango_Boy
Kona 1980
Yes. A fellow member wrote this paper to help deal with this same kind of problem.
Thank you DWncchs !
http://photos.imageevent.com/durango...%20Testing.pdf
Old Sep 26, 2007 | 09:33 PM
kona's Avatar
kona
Thank's for the link. Already looking it over.
Kona
Old Sep 26, 2007 | 09:42 PM
Durango_Boy
Kona
Very welcome. Finding a draw that big should be easy.
Old Sep 26, 2007 | 10:25 PM
VCuomo's Avatar
VCuomo
The battery is dead within 5 hours?
Please - do yourself a favor and don't drive it until you find the problem, and make sure to leave the battery disconnected except while you're troubleshooting the draw. Electrical fires and fiberglass don't mix too well...
Have you checked the starter?
Old Sep 26, 2007 | 10:27 PM
wombvette's Avatar
wombvette
Kona 1980
OH NO, its not a dead short. That would kill it, and everything around it in just a few seconds.
Old Sep 27, 2007 | 10:36 AM
jnb5101's Avatar
jnb5101
don't call a cut-off switch a bubba thing-if you do any work on the car, disconnecting and reconnecting the ground cable gets to be a real pita.
jeff
Old Sep 27, 2007 | 12:12 PM
VCuomo's Avatar
VCuomo
jeff
Plus I've got one in each of my Vettes as a safety precaution.
Old Sep 27, 2007 | 03:03 PM
7T1vette's Avatar
7T1vette
Having the disconnect in place makes it really easy to determine the magnitude of the current drain and to connect up for diagnosing it. Just connect your ammeter across the disconnect [with it in OFF position]. Start with the 10a. scale so you don't burn up the meter.
Old Sep 27, 2007 | 03:07 PM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
the first thing you want to do is remove all the fuses and see if the battery still dies. if the battery stays charged then the problem is in the accesories. start replacing the fuses one at a time till you can isolate which circuit is grounding. If it still dies with all the fuses out then disconnect the positive lead at the starter and see if it dies again. if it dies then replace the cable that goes from the battery to the starter if it doesnt then its somewhere between the starter and the charging system. at that point i would replace the starter first and see if it still dies or removeit and take it in to your local auto parts store and see if they can test the starter and your alt. to see if both are good or if one or both are bad.
Old Sep 28, 2007 | 07:14 PM
7T1vette's Avatar
7T1vette
the Dragon's strategy is good, but seeing if the battery goes dead is a pretty slow way to check. Hook up your ammeter (10 amp scale) across the battery disconnect to see how much current is being drawn when everything is "off" (remember to close the doors so the interior lights are not "on"). If you have more than a .1 amp draw, start pulling fuses--one at a time--until the current draw disappears; that will be the "offending" circuit. Then you just need to search that circuit until you find it. {Note: If you pull a fuse and there is no change in the current draw, just put the fuse back it...it isn't the problem.}
To Finding a short
