C3-tpi
Old Oct 8, 2007 | 08:56 PM
Phil Zell's Avatar
Phil Zell
Default C3-tpi
Hi all
If I make the conversion on a C3 from carb to TPI, what all parts are needed to make the conversion? Is hood clearance an issue? This will be for a 1975.
Old Oct 8, 2007 | 09:09 PM
Durango_Boy's Avatar
Durango_Boy
Originally Posted by Phil Zell
Hi all
There is a lot of information on this subject and you'd be a lot better off just doing an advanced search for TPI in the C3 Tech and Gen section.
Old Oct 8, 2007 | 09:38 PM
mrvette's Avatar
mrvette
DB is correct, do a search....tons of info that way...
short form answer is plenty of hood clearance IF you use the oval air cleaner from K/N and a speed density system....yo want to use a MAF sensor, that adds to plumbing problems....
either way, It's about a bolt on....
I put the computer up under the map pocket on my '72....but surely there are other locations.....
I did my own wiring harness, but I'm an old ET, so soldering a wire is easy....
Old Oct 8, 2007 | 09:46 PM
bruced267's Avatar
bruced267
Hood clearence should be no problem. Its a pretty easy job, I did the same modification to my 81. You can try ebay or the For sale section here. Make sure to get a as complete system as you can, the small parts was my down fall. Street and performance can make custom harness. ecm, chips. Do some good research.
Old Oct 8, 2007 | 11:14 PM
DR.Jay's Avatar
DR.Jay
Here is a thread I posted on the conversion on my '78. It is almost a bolt on, and there is alot of info here on the forum, and around the net. The TPI system I used is from an '88 Z-28 Camaro.
http://forums.corvetteforum.com/show....php?t=1580191
Old Oct 9, 2007 | 12:09 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
There are a couple of good books on TPI swaps available. Barnes & Noble or Borders should have them in stock, or you can get them through amazon.com.
Old Oct 9, 2007 | 08:54 AM
markdtn's Avatar
markdtn
Hood clearance is no problem. Do an advanced search on my username and TPI. I have posted a "primer" for TPI install in C3 with what parts are needed. I have 2 running myself, several more installs for others, and am very happy with them. Happy to answer any questions.
To C3-tpi
