portable garage
Old Oct 14, 2007 | 11:11 AM
carnut114's Avatar
carnut114
Default portable garage
I was thinking of getting one (metal frame / tarp kind). pros, cons?
How long does the tarp material last?
Eric
Old Oct 14, 2007 | 11:16 AM
jbowles49's Avatar
jbowles49
Default good results
I had one of these when I lived in Alaska. Absolutely top notch, however I added a plywood underlayment to the top because of heavy snow. I only used it my last five years there but could detect no apreciable wear to the material.
Good luck
Old Oct 14, 2007 | 12:24 PM
74vert's Avatar
74vert
what brands are you looking at? I need something for my cars too. I saw this one on ebay which is cheap ... I wonder if any of them have flooring (tarp floor or something).
http://cgi.ebay.com/9-X-17-PORTABLE-...QQcmdZViewItem
Old Oct 14, 2007 | 12:38 PM
jbowles49's Avatar
jbowles49
Default not this one
It seems the one I had was advertised in Hemmings and was a very heavy duty construction. Frame poles were 2.5 in or so and vinyl cover was quite thick. I wouldn't take a chance with that collapsing on my car.
Good luck
Old Oct 14, 2007 | 01:10 PM
carnut114's Avatar
carnut114
I was thing about getting the sams club one for 179.00. Looks like the same one that is on ebay.
Old Oct 14, 2007 | 04:07 PM
Artsvette73's Avatar
Artsvette73
I got one from Shelter Logic. I have to replace the top rubbed through from the metal supports. It is 4yrs old.
I have even painted both my cars in it
Old Oct 14, 2007 | 05:22 PM
68 NJConv 454's Avatar
68 NJConv 454
I've been doing my frame off in a tent by Cover-It.
Been about two years now. No leaks at all. Got it from PepBoys for about $199 two years ago. Not the best materials and not snow rated.
I welded gussets to each bend for the roof to support more weight and prevent the poles from spreading. Also ordered a second door from Shelter logic so I can zipper up both ends of the tent. I've definitely got my moneys worth so far. Not a permanent structure though, I can see the wear on the tent after two years. I'd spend more $$ on something that would stand more permanent. I've heard good things about Shelter Logic.
I do get nervous when it snows and am outside every hour with a shop broom pushing the snow off the roof. Won't take any chances with the car underneath. I wouldnt' feel confident with my tent if the snow started to pile up.
http://www.whiskey-rock.com/category...FTaoGgodqnOkfA
Old Oct 15, 2007 | 09:34 AM
TWINRAY's Avatar
TWINRAY
My cousin had (still has?) the Pep Boys one but make sure you have it anchored cause the wind blew his away. He had a small pickup under it and after he put it up again, he tied the tent to the pick up.
Old Oct 15, 2007 | 01:00 PM
dr1's Avatar
dr1
get one thats not so unnecassarily tall, mine was like a barn, it blew into my woods last october... i thought it was staked down well enough :P
my yard is too wide open, no wind protection
I looked out my kitchen window one afternoon at like 5pm and was just thinking, "huh... how come i can see that car?" It had the rake that was propped against the carport just laying against the car now, like nothing had happened.
Old Oct 15, 2007 | 01:09 PM
TWINRAY's Avatar
TWINRAY
I think Shelter Logic is the same (or new name, replacement company) as Cover It.
Old Oct 15, 2007 | 01:44 PM
allautomotive's Avatar
allautomotive
i have two tents i bought 4 years ago.
they are the 11x16 footers and they have lasted thru 4 harsh winters.
the ones i have are made by harnois and come with a lifetime materials warranty.i paid $300 canadian each.when i went to pick them up they had tents set up that had been up for almost 10 years and looked new.these are staked into the ground in a way that the harder the wind pushes on it the harder it diggs into the ground.
the only issue you will run into storing a car is moisture.
i keep a dehumidifier in the tent i keep one of my cars in.
heres a link http://www.harnois.com/eng/accueil.asp
Old Oct 16, 2007 | 09:36 AM
68 NJConv 454
I hear ya. I have cinderblocks on the bottom of each pole. The tent came with a "boot" on the bottom of each pole that I guess you can use with stakes, but I just drilled holes in the cinderblocks and bolted those "boots" to the blocks. Wind blows it but doesn't move it. I also have a very narrow driveway and have fences close to both sides and have a safety rope tied over the top of the tent to the two fences just in case.
I can take pics if anyone is interested in how I set it up. Just let me know.
-Brett
To portable garage
