Carb starts REALLY rich...
Old Oct 14, 2007 | 03:20 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Carb starts REALLY rich...
When I start her up, first thing in the morning, she runs REALLLLLLY rich....so much that it almost envelopes the car in a shroud of smoke. (Holley 670 Street Avenger) This lasts about 30-40 seconds then the engine smooths out, RPM's go to 1,200, ...no more rich smell, smoke or anything!!. When she warms up, I tap the accelerator and the RPM's drop to 800 (600 in Drive. As far as the rest of the day...she starts right up and purrs like a kitten...even if it sits for most of the day or if I drive it alot. I checked the plugs...normal (no rich indications or oil burning). The car performs perfectly (acceleration, cruising, starting, stopping etc etc etc)...it's just first thing in the morning....COUGH COUGH COUGH
How do you "lean out the choke"?
Old Oct 14, 2007 | 04:29 PM
lars's Avatar
lars
Rotate it to the "lean" position.
Better yet - yank the entire choke system off the carb and run the carb with no choke - a correctly set up Holley seldom needs a choke system to start and run well.
Old Oct 14, 2007 | 04:57 PM
Ironcross's Avatar
Ironcross
Thats right, a couple of pumps and it should be running.
Old Oct 14, 2007 | 05:10 PM
vetteguy75's Avatar
vetteguy75
I really would like to keep the electric choke. When you say "Rotate it" do you mean the large black round housing for the spring (the one with the 3 screws holding it to the side of the carb)? If so, do I rotate it to the left or right
Old Oct 14, 2007 | 07:36 PM
vette blue's Avatar
vette blue
The edelbrock that came with my 71 didn't come with a choke and I drive it as long as there is no snow on the roads right down to as cold as 5 degrees fahrenheit and it starts just right. If you can't get the choke adjusted right try it without the choke just to see how it goes.
Old Oct 15, 2007 | 09:10 AM
Jims79's Avatar
Jims79
Not sure on the holley but I think you would turn to the left (not much 1/8 turn of a flat screw driver). then restart and see if it made any chg.
Old Oct 15, 2007 | 12:23 PM
Bob Onit's Avatar
Bob Onit
Loosen the 3 screws and rotate the entire housing to adjust the choke.
Clockwise (lean) will open the choke quicker.
It should be marked "Rich" and "Lean" right on the choke housing.
You can test the 12V connection with a test light or just turn the key on and watch the choke blade.
It should open gradually over a period of a minute or so depending on where you have it set.
Old Oct 17, 2007 | 08:17 AM
vetteguy75's Avatar
vetteguy75
I turned the black housing 2 clicks clockwise....saw the choke blade "open" just a little....and now it is working perfectly. THANKS! I was tired of breathing gas fumes at start up....
Old Oct 30, 2007 | 10:13 AM
HUSKER-Z's Avatar
HUSKER-Z
I too have the same problem, but can't find the place to lean out this mixture. Anyone have a pic? I have a 76 stock carb.
Old Nov 1, 2007 | 09:53 AM
HUSKER-Z's Avatar
HUSKER-Z
bump
Old Nov 1, 2007 | 11:33 AM
lars's Avatar
lars
If you have a stock carb, drop me an e-mail request for my Q-Jet Choke Adjustment Paper:
V8FastCars@msn.com
You likely need to replace and adjust your choke pulloff - the pulloff controls start-up mixture and choke setting.
Lars
Old Nov 2, 2007 | 01:57 PM
HUSKER-Z's Avatar
HUSKER-Z
emailed ya!! thanks lars!
To Carb starts REALLY rich...
