#4 body mount
Old Oct 16, 2007 | 09:49 AM
chivic's Avatar
chivic
Default #4 body mount
Does anyone know what size the holes should be in the frame brackets for the #4 body mounts? Mine were so rusted I couldn't measure them. I don't know if they are the same as the #1's or not. Thanks for the help !
Old Oct 16, 2007 | 10:29 AM
vettedan's Avatar
vettedan
There are the same.
Old Oct 16, 2007 | 11:20 AM
Bruce C's Avatar
Bruce C
Did you look into buying them already made?
I have to do replace mine as well, but I don't have the equipment to make them.
Old Oct 16, 2007 | 01:04 PM
Dan Herring's Avatar
Dan Herring
Cruising
They are the same size. I just replaced mine.
Old Oct 16, 2007 | 01:25 PM
iree75's Avatar
iree75
I welded mine up, but Volunteer sells the frame brackets.. would have been a better way to go.. I'm sure others make these (or resell) them as well.
http://www.volvette.com/page/VVP/PRO...oyd-mount/BM66
-F
Old Oct 16, 2007 | 01:36 PM
chivic's Avatar
chivic
Thanks for the help. I made mine also. I couldn't see paying $40 a piece for them from ZIP.
Old Oct 16, 2007 | 01:59 PM
LYLE's Avatar
LYLE
I just replace the top with the hole in it and make the weld on the corner both sides. Grind the corners round and your done and the location is perfect as the sides are reused. I think the hole is 1 and 3/16 but check the front to make sure. With the plate made its a ten minute job.
To #4 body mount
