Alignment
Old Oct 22, 2007 | 10:48 AM
kmobrien76's Avatar
kmobrien76
Default Alignment
Need an alignment, she tracks a wee bit to the left and I need to hold the steering wheel...
I work for a dealership, my service mgr. said he'll have it done here if I pick up the shims...
Should I get front or front and rear, from my limited "googling" I read that I should buy the following:
http://www.zip-products.com/Zip/prod...=BAN_CMarticle
63-82 UPPER CONTROL ARM ALIGNMENT SHIMS
and;
rear control stainless shim set with the bolts and two new cotter pins...
Thoughts?
Are shops like Firestone (chain) reputable to do alignments on our babies?
Thanks in advance,
Kevin
Quincy, MA
'74 Stingray or Sting Ray I forget
Old Oct 22, 2007 | 11:48 AM
Peterbuilt's Avatar
Peterbuilt
Default Alignment
Hi Kmobrien,
The pulling to one side could be the power steeing control valve needs an adjustment.
Most shops will have some extra front control arm shims.
The trailing arm shims can take hours to get loose. Buy them and two new bolts and install them yourself, than any shop can give you a proper 4 wheel alignment.
In 74 its a STINGRAY.
Hope this helps, Pete.
Old Oct 22, 2007 | 11:52 AM
kmobrien76's Avatar
kmobrien76
Thanks Pete!
Kevin
Old Oct 22, 2007 | 02:23 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Don't you have an alignment shop near you? Forget tire stores. Any alignment shop worth it's salt should have shims. The front end on your car is standard GM issue (for the era), nothing special.
Conventional Short/Long Control Arms, spring & shock between the two, bottom ball joint loaded.
If that type of front end confuses your shop, you need to find a different alignment facility.
Old Oct 22, 2007 | 02:30 PM
kmobrien76's Avatar
kmobrien76
Sounds good, my local race shop recommended a shop, they are a chain and highly recommended, appointment made, hope it goes smoothly...
Kevin
Old Oct 22, 2007 | 04:39 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Harbor Freight sells a "Storehouse" box of shims.
Old Oct 22, 2007 | 07:51 PM
7T1vette's Avatar
7T1vette
Your best bet is to take it to a Chevy dealership (if you work for one, all the better). They do them often and know how to do them correctly...especially the rear wheels. Don't take it to a "tire store" or general purpose alignment shop unless you know that the are skilled at working on Corvettes. Most of those kind of shops are in business to find lots of "serious" defects in your car so that they can save you from a serious accident for only $500! Take it to the "source".
Old Oct 22, 2007 | 07:55 PM
Mia's Avatar
Mia
Wish I would have noticed this prior to my post.. I'm planning on rebuilding the front end myself, ie., replace tie rod ends, ball joints, etc., then take it to get aligned.. So assuming I do all this, it sounds like the dealer is the place to go?
That said, what can one expect to pay on average for the front end alignment?
Old Oct 22, 2007 | 08:04 PM
phclub's Avatar
phclub
New England Events Coordinator
Default Alignment in Arlington
Hi, I had my 70 vert front end rebuild done in late 2005 and in early 2006 visited Mirak in Arlington 781-643-8000 ask for Doug in the body shop. They take their work seriously on corvettes. I was very pleased with the alignment. The car tracks straight as an arrow. Let me know if you have further questions.
Body Shop Hours:
7:30am to 6 pm Mon - Friday; closed Saturday
Mirak
1125 MASSACHUSETTS AVE
ARLINGTON, MA 02176
www.mirak.com
Old Oct 23, 2007 | 04:18 PM
TWINRAY's Avatar
TWINRAY
IMO, the dealer is the last place to go. The mechanics are paid on the quantity of work they do and not the quality of work. I'd "ask" around your area. The rear shims for tow on a Corvette need to be done by someone who knows what they are doing. A lot of places don't even do rear tow.
Old Oct 23, 2007 | 05:38 PM
PeteZO6's Avatar
PeteZO6
The Chevrolet dealers I know of around here seem unable to correctly diagnose and service new cars, let alone ones that are older than a lot of their techs. It took me three visits to the local dealer to have the headliner replaced in my Z. First was to order the part under warranty, second was to replace the headliner and the third was to put in new sun visor retainers as they are one-time items and weren't ordered with the headliner. What a waste of my time!
Find a good experienced independent alignment shop for working on your shark. Ask around; other owners, Corvette specialty shops, etc., and then talk to the person who will do the work. Make sure he/she had aligned C2/C3 Corvettes and knows them well. Front end cost will probably be the prevailing rate for most cars, but the rear might be twice that amount because of the work involved. With a good alignment your shark should drive down the road straight and true, and as an added bonus, it won't pull to either side under braking.
Old Oct 23, 2007 | 07:01 PM
Mia's Avatar
Mia
Well, the dealer I talked to today I've known and worked with for years.. After talking about the alignment needs of mine, they said they have worked on more 70's Vettes than new ones. They said they have a good alignment guy and I will not be disappointed. I was quoted $70 + shims if necessary..
Old Oct 23, 2007 | 07:26 PM
SmokinBBC's Avatar
SmokinBBC
$70 for both the front and the rear?
Old Oct 23, 2007 | 07:32 PM
Mia's Avatar
Mia
Sorry, should have said $79.95 for 4 wheel... They have a sale going on ATM..
BTW, anyone have an opinion on the "SU01B_69-82" front end deluxe rebuild kit for the 1979 Vette?
I am thinking of getting it from these guys: http://www.volvette.com/Merchant2/me...de=SU01B_69-82
I plan to redo the front end before doing the alignment so there are not hidden surprises.
Old Oct 23, 2007 | 07:50 PM
SmokinBBC's Avatar
SmokinBBC
$80 for 4 wheels is a bargain for guys with older vette experience. But if you have rotted bushings in either the front or rear, they probably won't touch it.
Since you are doing the front, that won't be an issue. BTW, check with volvette on what brand parts are in the kits...ie: moog ball joints, etc.
Your problem with the alignment will come with the rear..worn out bushings and rusted trailing arm pivot bolts.
Old Oct 23, 2007 | 08:01 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I've never heard of anything bad about Volunteer's parts. I get most of my suspension and brake stuff from either Van Steel or VB&P, though.
Old Oct 23, 2007 | 09:06 PM
Mia's Avatar
Mia
The brunt of the problems are with the camber and toe on the front. It pulls hard to the right. The rear looks good.
That is good to know.. I was looking at VBP, but the Volunteer has free shipping and is about $20 cheaper on the kit.
Old Oct 24, 2007 | 08:02 AM
Trae1976's Avatar
Trae1976
That's the kit I used - no problems here.
Edit: Though I went with the poly bushing kit instead of rubber.
Old Oct 24, 2007 | 09:24 AM
TWINRAY's Avatar
TWINRAY
My .02 - get poly bushings. You'll get faster steering response and never have to worry about replacing them again. Rubber will dry rot. #2 - get poly boot covers for your ball joints and tie rod ends. #3-don't buy kits that have "no-name" parts from China . I wouldn't use anything other than Moog. You shouldn't concern yourself with "saving a few bucks" unless you know you are getting quality parts. Do it right the first time and you're set for many years. Been there, done that.
To Alignment
