Why do people and GM put different size wheels on the front and back of Corvettes. The people with 17 18 combo’s on their c-3’s, are the rolling diameters the same? Do the front and rears have the same profile tire? I am trying to pick what size wheels to get and I do not want lower profile tires on the rear. I think I may want 17’s just to not have too low a profile tire.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
If you want to run wider tires on the back and keep the sidewall height ( profile ) and overall diameter close from front to back you end up having to go with different size wheels on the front and back I have 17in on the front and 18 on the back
I am glad I asked this question before I buy wheels. I would like to go with wide wheels/tires in the back. So as I understand from what motorhead is saying if I have say 17x8 in the front and 18x10 in the back I can have the same profile (sidewall height) on the front and the rear? This would make the rolling diameters different then.
I like the way this combo looks on wnjlt1’s car.
On my 68, I put different size tires, smaller on front and bigger on back. It has the look of different size wheels, but I am running 15x7 wheels all around. I think the front is a 235 and the rear is a 255. The profile is normal and the car looks great. Maybe you could buy one wheel size and just change the tire sizes.
Keep in mind that if you chose to run different size tires or rims from front to rear you wont have the option of rotating the tires anymore which will shorten the life of them.
I have never understood this philosophy, how can it shorten the life of your tyres? Sure if you dont rotate them your rears will wear out faster and you will have to replace them earlier, but your fronts wont wear out so fast so they will last longer and therefore balance out so that ultimately the tyre costs will equalise.
Actually the fronts usually wear out faster... unless you do a ton of burn outs.
Smaller tires in front generally generates a tad bit of understeer, hence why cars come that way stock, usually. I run 275-40-17s all around, handles sooo much nicer than anything you can put on 15 inch rims, since Pirelli stopped making Scorpion Zeros in 255-60-15.
I have 285 - 17's front and 345 - 18's rear..slightly taller rear tire for a nose down stance.
Did try to rotate the tires once...steering was veryyyyyyy heavy
gordonm, wow after seeing your pics and the action shot in your profile, I think I am swayed to going with the 17 18 combo. I like the painted center tt’s that’s what I was planning on going with. They look nice on a chrome bumper car. What brand tire do you run?
I run 18's all around. I wanted 18's on the front to clear 14 inch rotors. The cost is the same so why not go 18's all around???
The stock rotors do look small inside an 18 inch rim.
For the front on my last set i went cheap because i was on my way to the alignment shop. My front KDW's are showing cord through from a day at the track and a wild double 360 spin.
But I'm impressed with the 255/45/17 kumho's. I did a set of 5 hot laps and my brakes were gone completely so i had to go into the pits. They were actually pretty good. Nice control on the street. They have to much rain groove for my dry climate. I would rather have more rubber on the road.
The front tires I have on now are cheap Fuzion ZR1 tires. They perform pretty well for an inexpensive tire. The rears I have a set of Kumhos. I like them quite a bit. Also an inexpensive tire but a good tire and always gets good reviews. I will eventually go with the Kumhos on the front also. They are the same as Gkull is showing.
