Ride height problem????
Old Oct 23, 2007 | 12:38 AM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Default Ride height problem????
I just installed a set of KYB Gas A Just's this weekend on my 77
Not the car seems to be sitting about 2 inches taller..Is this normanl?
WIll the shocks settle?
Is there a way to adjust the shocks?
Dont get me wrong the car drives great just sits taller now.
Old Oct 23, 2007 | 01:46 AM
LB66383's Avatar
LB66383
If a gas-filled shock will affect the car's height at all, it's rarely enough to be noticeable. They won't raise a car two inches.
Old Oct 23, 2007 | 02:53 AM
Vesa's Avatar
Vesa
its not the shocks it must be something else that happened during assembly
Old Oct 23, 2007 | 10:06 AM
ptroxx's Avatar
ptroxx
I just put shocks on the car nothing else.. WHat else could have happened??
Old Oct 23, 2007 | 10:35 AM
Garys 68's Avatar
Garys 68
Is it the rear only that sits higher?
If so, the rear sway bar links can "flip" and jam, holding the rear up an inch or two.
Old Oct 23, 2007 | 10:44 AM
pbcanney's Avatar
pbcanney
"Designed to deliver maximum driving control, KYB's Gas-a-Just® High Performance Shocks provide a high performance ride. Gas-a-Just® High Performance shocks’ higher gas pressure keeps tires glued to the road while its superior strength monotube design with floating piston makes for fade-free performance and the seamless cylinders and eye rings provide durability. The Gas-a-Just® High Performance Shocks offer a wide range of applications including RVs and motor homes." <- from KYB site
whats the 'a-just' part?
I've been looking at these for my 81.
Old Oct 23, 2007 | 09:33 PM
ptroxx's Avatar
ptroxx
I was thinking the same thing.. Cause they dont A-Just !!
But like it says they sure do make the car hug the road...
Im thinking now i can put some different tire on the car. A little wider in the back.
Not realy sure yet ..
Old Oct 23, 2007 | 09:34 PM
ptroxx's Avatar
ptroxx
Seems like the front and rear are a little higher. ?????
Old Oct 23, 2007 | 09:49 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I think you've just been breathing exhaust fumes from that brown truck too long Drive it for a couple of weeks and see if it starts to look normal.
Paul
Old Oct 24, 2007 | 05:24 AM
RunningMan373's Avatar
RunningMan373
Man, your 'vette is all over the place. I guess when you say "hug the road" you mean it!!! , first it's all bent out'a shape, now it's 2" higher? I think it's time you put it on a drive on lift and took a good look at the frame, body mounts and suspension.
Old Oct 24, 2007 | 10:04 AM
ptroxx's Avatar
ptroxx
Paul
Old Oct 24, 2007 | 10:20 AM
Durango_Boy's Avatar
Durango_Boy
What shocks did you buy and from who were they purchased?
Could they be for a different application?
Old Oct 24, 2007 | 10:30 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Ride height is controlled by the springs and has nothing to do with shocks.
Old Oct 24, 2007 | 11:16 PM
ptroxx's Avatar
ptroxx
Hey Matt, I got KYB's Gas A Just's from ebay.
And I tossed the boxes that they came in.
This could all be in my head too... But its almost a fist width from tire to fender... ?
Old Oct 25, 2007 | 12:22 AM
Scott Marzahl's Avatar
Scott Marzahl
The shocks should have the part numbers stamped into the metal at the bottom of the tube base. You could have the wrong part numbers.
Old Oct 25, 2007 | 01:32 AM
PeteZO6's Avatar
PeteZO6
Hi ptroxx,
If that were my car, I would look up the ride height specs in the Chevrolet shop manual and then measure the car. That way I'd know exactly where the car is vis a vis what it should be; to high, too low, just right. Knowing that would make it easier to decide what, if anything, needed to be done.
PS. I used to live on Railroad Ave., near 101.
Cheers,
Pete
Old Oct 25, 2007 | 08:36 AM
Jud Chapin's Avatar
Jud Chapin
Another suggestion would be to take the front shocks off or just unbolt the bottoms and see what happens. That will tell you if your shocks are affecting your ride height. I'm sure you know, but in case you don't, be sure to have the car jacked up with supporting stands on the frame while unbolting the lower shock bolts.
To Ride height problem????
Old Oct 25, 2007 | 09:46 PM
ptroxx's Avatar
ptroxx
Originally Posted by PeteZO6
Hi ptroxx,
Cheers,
Pete
Hey Pete thats a great idea.. Why didnt I think of that... I guess thats why we aske questions... I have the service manual I guessthat info should be in there. ....
Good old cotati...Railroad is one of my short cruising roads. I go downtown then make my way to petaluma hill road... Then back to Rohnert park.....
Thanks for the info Pete
George
Old Oct 25, 2007 | 09:47 PM
ptroxx's Avatar
ptroxx
Another great idea....This is an easy task to see whats going on..
George
Old Oct 26, 2007 | 12:34 AM
Jud Chapin's Avatar
Jud Chapin
You're welcome!
