PCV question
Old Oct 27, 2007 | 06:39 PM
Belgian1979vette's Avatar
Belgian1979vette
Default PCV question
Would a pcv still work if only connected to one cylinder on an IR manifold ?
Old Oct 27, 2007 | 07:01 PM
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
I think it would, but may foul that spark plug on the cylinder due to all of the engine's blowby being dumped into one cylinder instead of being distributed evenly.
Old Oct 27, 2007 | 08:49 PM
VettePower's Avatar
VettePower
Okay, I give up!! toatlly baffled!! how do you plug a PCV valve into a cylander?? i thought mine is in my valve cover!!!!
Old Oct 27, 2007 | 09:44 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
Old Oct 27, 2007 | 10:16 PM
VettePower's Avatar
VettePower
Say What?????? That sounds like a big load of....
Old Oct 27, 2007 | 10:58 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Talking about that long-tube injection cross-ram manifold, I assume? I don't think it would really have much of an effect.
Old Oct 27, 2007 | 11:00 PM
Z-man's Avatar
Z-man
You might get away with it if there isn't a lot of oil in the blow by...
Old Oct 28, 2007 | 12:06 AM
St. Jude Donor '09
So you think dumping all of the engines blowby into one cylinder wouldnt have an effect on that cylinder?
Old Oct 28, 2007 | 05:54 AM
Belgian1979vette
Yes, although long tube... the tubes are something like 11".
Old Oct 28, 2007 | 09:03 PM
VettePower's Avatar
VettePower
I am so friggin confused.............................
Old Oct 28, 2007 | 09:17 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
IR manifold == independant runner manifold.
But I agree that you will swamp that one clyinder with the PVC.
There must be a better way
Old Oct 28, 2007 | 09:42 PM
olescarb's Avatar
olescarb
i would avoid using one cylinders runner as the vacuum source for the pcv valve not only because of the blowby but even more importantly you are giving that air leak/air flow from the pcv to only one cylinder. this would cause that cylinder to run leaner than the rest. I always try to hook the pvc to a central location (base of the carb) so all the cylinders are seeing the same air leak.
i hope this helps henry @ olescarb
Old Oct 29, 2007 | 03:26 AM
LeapinLizard's Avatar
LeapinLizard
Default I'm Positive the Crankcase won't Ventilate itself.
Positive Crankcase Ventilation valve...
Yes, but...
Why wouldn't you connect it to the common part of the air intake somewhere? Its only function is to forcibly evacuate fumes (water vapor, solvents, etc.) from the air spaces in the crankcase.
The best thing for these fumes is to burn them in the combustion chambers. All the combustion chambers. If you have oil "blowby", you have a different problem.
Here's a thought: Try it. Run a thousand miles, then read your spark plugs. Tell us what you find. Thanks in advance.
Old Oct 29, 2007 | 08:36 AM
V-Twin's Avatar
V-Twin
The guy has an individual runner intake. That means he has NO common plenum, each cylinder has his own throttle blade.
You have to either plumb the underside of the manifold for a common take off tube that exits somewhere, if you do it near the distributor it will be almost invisible, like a sneaky pete setup. You'll also need that if you have a vacuum advance distributor. Time to break ouyt the drill, tap, tubing bender and flare tool. Otherwise you'll need to run scavenging valves on the collectors
Old Oct 29, 2007 | 08:38 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Old Oct 29, 2007 | 12:57 PM
Belgian1979vette
I was affraid that this would be the answer. The problem is, i need to tap it for 3 things : PCV, vacuum and IAC. That's going to be a lott of tubing under there.
Old Oct 29, 2007 | 01:44 PM
V-Twin's Avatar
V-Twin
Didn't the manifold ome ready for IAC? You don't have to do all the plumbing on the underside, it just looks neater. You can also do some in the center. Are there no additional ports on the throttle bodies for idle control?
Old Oct 31, 2007 | 07:07 AM
Belgian1979vette
No ports, just an idle screw that adjust the throttle blades.
To PCV question
