e85
Old Oct 30, 2007 | 07:28 PM
edlebby's Avatar
edlebby
Default e85
is it possible to run e85 on a stock 350 for a 70-72 C3? - is it possible to make so modifications so you could? - 105 octane at the pump is pretty tempting....!!! - thanks, ed
Old Oct 30, 2007 | 07:34 PM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
Your biggest problem will probably be in dealing with upgrading everything that ethanol is going to touch.
Your whole fuel system will need updating.
Old Oct 30, 2007 | 08:11 PM
longbros's Avatar
longbros
Why?
Old Oct 30, 2007 | 08:31 PM
chris75stingray's Avatar
chris75stingray
i think the ethanol eats away at rubber lines and gaskets???
Old Oct 30, 2007 | 08:34 PM
Entropy's Avatar
Entropy
Originally Posted by longbros
Why?
there's your answer.
Old Oct 30, 2007 | 08:40 PM
longbros's Avatar
longbros
Ethanol has been mixed in gasoline and used in vehicles for years with no problems. The mix I believe was 10%. I can't imagine that 15% would make that much difference.
Old Oct 30, 2007 | 08:47 PM
longbros's Avatar
longbros
My mistake!! I guess I am half alseep in this computer chair. E85 would be 85% ethanol and 15% gasoline. You are correct, it would attack the lines, gaskets, and most likely many metal parts. I stand corrected. Shoot, I even sit corrected!!
Old Oct 30, 2007 | 08:56 PM
vetteaddic's Avatar
vetteaddic
Some say you need this and that who knows ,Ive seen tests of e85 in a Suburban on youtube that showed it to run well and even disassembeld the motor and tank to show if any harm was done,
but who knows if thats a bogus clip.
You need to jet up on the carb because e85 is less efficient so you burn more fuel.
Old Oct 30, 2007 | 09:01 PM
BigBlockk's Avatar
BigBlockk
Why?
(1) Because, when setup properly, an E85 motor will make more power than a gas engine.
(2) Because, when tuned correctly, an E85 engine stays cleaner inside than a gas engine.
(3) Because E85 is cheaper than premium (for now).
(4) Because it means we can get away from buying oil from our peace loving Arab friends.
BigBlockk
Later.....
Old Oct 30, 2007 | 09:41 PM
SpeedCoach's Avatar
SpeedCoach
i read something about this recently...if i remember right all the metal parts that come in contact with E-85 have to be stainless as it corrodes pretty much everything else...
Old Oct 30, 2007 | 10:04 PM
longbros's Avatar
longbros
BigBlockk
Later.....
Hey BigBlockk,
I wasn't questioning the benefits of E85, I was just questioning why the fuel system would need to be upgraded. Now I understand. I see nothing wrong with E85.
Old Oct 30, 2007 | 10:40 PM
FRSTR90's Avatar
FRSTR90
Hey BigBlockk,
E85 to my knowledge is not a performance fuel... It is nothing like 103 racing fuel.
That is correct.. Edelbrock had an E85 600 CFM carb in the works and was suppose to be available last April. I wonder what happened...
Old Oct 30, 2007 | 11:01 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
E85 is 85% ethanol. Here's a link for those of you interested. In the fine print, it appears it could be illegal to convert without certification. (??) Hope I'm wrong about that.
http://www.e85fuel.com/e85101/questions.php
Old Oct 30, 2007 | 11:24 PM
edlebby's Avatar
edlebby
TSW - that is the website that got me thinking about all of this...back to FRS's point - why wouldn't this be like 103 racing fuel - I mean...I am not saying it isn't ... just want to understand ...one answer might be that ethanol does not contain the same energy per unit as gasoline - but what does octane do? - given that ethanol has 105, does that mean more hp but less efficiency? - and can anyone confirm that apart from increased aggressiveness to rubber, that it is corrosive to metal? - thanks!! - ed
Old Oct 31, 2007 | 12:12 AM
FRSTR90's Avatar
FRSTR90
That is it. Ethanol doesn't produce the same amount of BTU's as Gasoline. When ethanol ignites in the cylinders it doesn't produce the same amount of cylinder pressures as gasoline. You get what I am saying?
Old Oct 31, 2007 | 12:36 AM
TheSkunkWorks
I knew I was pretty sure that you knew, but I didn't know who didn't know, so I wanted to make sure that everyone knew what we knew (know?)...
Old Oct 31, 2007 | 12:37 AM
BigBlockk's Avatar
BigBlockk
Hey BigBlockk,
Sorry 'bout that.
BigBlockk
Later.....
To e85
Old Oct 31, 2007 | 12:52 AM
BigBlockk's Avatar
BigBlockk
There is no reason why it could not be used in a performance setting. It is a very good fuel. Indy cars and sprint cars have used it (ethanol). It has been used for detonation control in supercharged and turbocharger applications.
The only two downsides are its lower energy content and its latent heat of vaporization. The second one is why they mix it with gasoline. In the winter E85 would become E70.
BigBlockk
Later.....
Old Oct 31, 2007 | 01:34 AM
jackson's Avatar
jackson
Default you don't get something for nothing
Only rather recent & Very limited Ethanol fueled Indy & Sprints ... for 40+ years & until recently they'd all run on Methanol ... AFAIK, only IRL has gone totally Ethanol. Methanol & Ethanol similar alcohols but different.
Methanol = CH3-OH (drink & die)
Ethanol = C2H5-OH (drinkable)
Both are corrosive ... alky race cars require & have fuel systems designed for alky ... doubt much long-term success w/ any old gas car running hi% of any alky. Once you did get it worked out, you'd be filling ALOT more often than w/gas ... you'll use alot more alky /mile ... same true for current E85 crappy mileage.
Rant: Friends ... please don't fall for nor offer your tax $ to CORN-based ethanol boondoggle. Alky can help our short-term fuel thirst, but corn is not the wisest rawstock for a chemical process ... corn is best-used as food.
Old Oct 31, 2007 | 09:12 AM
stingr69's Avatar
stingr69
Not only would you have to stop for refueling more often per mile it will end up costing more to drive if we adopted this as an alternate fuel strategy. The economics are not favorable as a significant source of alternative fuel. We would have to see a huge change in the way people feed themselves not to mention that corn has to be cultivated and processed before we can refine it into fuel which adds to the cost. We don't have anywhere near the amount of excess corn available to significantly impact the reliance on fossil fuels. There needs to be another solution.
-Mark.
