C-3 Help Again...
Old Oct 31, 2007 | 03:32 PM
GEORGE TAYLOR's Avatar
GEORGE TAYLOR
Default C-3 Help Again...
I Am Putting Together My Steering Now. And Need Help.
When I Bought The Car It Was Appart And Not Very Well Cataloged. My Question; With My Steering Box Bolted In The Steering Shaft From The Steering Wheel Does Not Line Up.(at An Angle)
I Found 3 Groups Of Taped Together Heavy Duty Shims Marked Top, Bottom And Front. They Are All Of A Different Size.
Do These Go In To Shim The Steer Box To Meet The Steer Shaft? I Placed Them In And The Box Lined Up. Just Want To Make Sure.
Thanks In Advance
Geo.
Old Oct 31, 2007 | 04:15 PM
69monzacpe's Avatar
69monzacpe
Mine doesn't have shims, just bolted straight on the frame with no alignment problems.
I'm curious to see if anyone else has shims. If not, your frame may be bent....I hope not
Old Oct 31, 2007 | 04:44 PM
71rdster's Avatar
71rdster
No shims here. Lines up perfectly.
Old Oct 31, 2007 | 05:12 PM
Alan 71's Avatar
Alan 71
71-#6589... sorry, no shims either.
Old Oct 31, 2007 | 06:20 PM
Duke94's Avatar
Duke94
No shims. The shims you have must be for the control arms. If I'm not mistaken, the steering column is at an angle as designed by GM.
Old Oct 31, 2007 | 06:45 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
George - if the steering shaft does not line up with the steering box input shaft, it is adjusted by adjusting the column. Loosen the 2 bolts at the plate on the column and the 4 bolts on the interior column mount. Align the shafts by moving the column left or right. Adjust the up & down at the firewall.
Oh - no shims!
John
Old Nov 5, 2007 | 05:10 PM
GEORGE TAYLOR
Default Thanks To All
It Appears That My Coulm Was From Another Car. I Will Remove The Shims And Try And Adjust .
Thanks Again.
Geo.
Old Nov 5, 2007 | 06:45 PM
chuck d's Avatar
chuck d
I think Jim Shea has an article on the forum somewhere on the proper way to install the steering column . Do a search for this article .
Old Nov 5, 2007 | 06:51 PM
63_GrandSport's Avatar
63_GrandSport
Jim Shea link.
http://jimshea.corvettefaq.com/?page_id=4
Old Nov 5, 2007 | 07:12 PM
indy99's Avatar
indy99
From: the land of a never ending frame-off resto-mod. May Visa have mercy on my soul.
I have an 80 and I had shims where the column bolts to the dash area.
To C-3 Help Again...
