Rag Coupling Shouldered Bolts.
Old Nov 1, 2007 | 05:05 PM
chuck d's Avatar
chuck d
Default Rag Coupling Shouldered Bolts.
A few years ago I rebuilt my steering box and installed a new rag coupling. I have only recently read Jim Sheas's papers on the subject. Now I have discovered that the bolts that hold the two flanges together are not shouldered bolts as the OEM coupling had. The rest of the coupling seems orientated OK. The original coupling is long gone. My question is: are these shouldered bolts available anywhere? Can these bolts be found in any other GM application (junk yard)?
Old Nov 2, 2007 | 07:19 AM
Jim Shea's Avatar
Jim Shea
The special shoulder bolts are not available through GM and I doubt that they are available elsewhere. However, every GM flex coupling since 1970 has these two shoulder bolts. I would expect that you could find one at a salvage yard. Corrosion on the threads would probably be the biggest problem with salvage yard parts. There are two little round keepers that prevent the shoulder bolts from falling out during shipping from the factory. You really don't need them.
One other consideration. Your rubber disc has been "mashed" in position for a couple years now. The disc may already have taken a set where it is now less than 3/8 of an inch thick. The special shoulder bolts have shoulders that are 3/8 inch long. They may not even squeeze your current rubber disc. That could result in loose steering because the rubber won't really be trapped and carrying much of the steering load. It might be time for a new rubber disc as well.
Jim
Old Nov 2, 2007 | 10:04 AM
chuck d's Avatar
chuck d
Jim
Thanks Jim for the response. Your postings and papers on the steering subject are great.I just remembered I have another steering box out of a wrecked Corvette. I will take a look at that one and see if the coupling is still installed on it. Maybe on the other hand I should think about springing for a new GM unit. Gm parts direct has them listed under the number you wrote in your articles. Thanks again.
Old Nov 2, 2007 | 03:37 PM
Darrel1's Avatar
Darrel1
I bought a new coupler from Vette Products of Michigan and it had all the correct parts (per Jim's paper) even the little plastic alignment clips.
Darrel1
Old Nov 2, 2007 | 04:40 PM
GTR1999's Avatar
GTR1999
You're better off getting the GM rag joint. It's still avail from GM
Old Nov 3, 2007 | 05:12 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The kit from the "Help!" aisle at the parts store should have the correct bolts.
Old Nov 4, 2007 | 09:46 AM
chuck d's Avatar
chuck d
Thanks for everyones input.
Old Nov 4, 2007 | 01:30 PM
Jim Shea's Avatar
Jim Shea
That has been the problem. Most "help" kits do NOT include shoulder type bolts. I am not even sure if the overseas manufactured full flex coupling assemblies have shoulder bolts. I certainly hope so.
I have written to over a half dozen suppliers with my concerns about lack of shoulder bolts (and about gear flanges being machined backwards). A very few responded that they were checking the situation. No body has responded that the problem has been corrected.
Jim
Old Nov 4, 2007 | 01:39 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Jim
Jim, that's very interesting. The kit I used had parts that looked just like the originals in my coupler.
Old Nov 4, 2007 | 01:58 PM
LYLE's Avatar
LYLE
I will say if you put those shoulder bolts in the wrong side the steering wheel is 180 off.
Old Nov 4, 2007 | 02:16 PM
chuck d's Avatar
chuck d
I found some shouldered bolts on another Corvette steering box I had. The coupling itself is junk, but the bolts seem useable. If the used bolts don't work out I think I will be investing in a new GM coupling. Probably from GM parts direct.
Old Nov 4, 2007 | 03:40 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Been there, done that.
To Rag Coupling Shouldered Bolts.
